Old 7th April 2004, 06:57 PM   #1
moving_electron's Avatar
Location: Where the rain does fall but the trees grow tall
Default Definition of 4th order acoustic crossover
Does 4"th order acoustic slope" in a crossover" simply mean a typical straight 24dB crossover such as a Linkwitz-Riley or does it have some other meaning?
Old 7th April 2004, 07:00 PM   #2
tiroth is offline tiroth  United States
It means that the sum of the electrical and driver acoustic responses is 4th order LR.
i.e. you take into account the acoustic response of the driver, instead of assuming it is maximally flat.
Old 7th April 2004, 07:01 PM   #3
It means eventual acoustic roll-off is 4th order which
means the crossover is probably electrically 2nd order.
sreten.
Old 7th April 2004, 09:59 PM   #4
Actually, there is some room for confusion here.
I have actually seen crossovers called 24 dB slope when they were actually just second order. Some people actually include the slopes of both drivers. So two drivers each having 12 dB slopes gets called a 24 dB crossover.
Normally, it doesn't work that way, but you do run into that terminology sometimes.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 8th April 2004, 12:21 PM   #5
speaker is offline speaker  United States
speaker's Avatar
Sounds like some people need a slap upside da head.
Haven't heard that transmogrification before.
speaker
LR 4th order vs LR 8th order crossover redliner Subwoofers 1 7th January 2009 11:32 PM
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
first order crossover svokke Multi-Way 15 8th April 2005 08:48 PM
Acoustic Crossover kspv Multi-Way 3 8th July 2004 02:07 PM
Crossover - 1st Order GeniX Multi-Way 3 20th September 2002 02:39 PM
Page generated in 0.06363 seconds (83.25% PHP - 16.75% MySQL) with 10 queries
