Sticker on magnet over vent
Old 21st January 2018, 07:21 AM   #1
Mrcloc is offline Mrcloc  South Africa
Default Sticker on magnet over vent
Hi. I can't seem to find information on this. My two extra visaton w170s' arrived today, and I was looking at them (as one does when getting new toys), and I noticed the sticker on the back covers the vent in the magnet. Should I leave it? Should I tear it off? Will it have an effect on the parameters?
Old 21st January 2018, 07:26 AM   #2
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
Can you post a picture?
Normally the vent on the back side of the magnet (vent of voice coil) should be left free.
Old 21st January 2018, 07:31 AM   #3
Thanks, here's a picture.
Old 21st January 2018, 07:34 AM   #4
Is there a hole (for voice coil cooling) under the sticker?
Old 21st January 2018, 07:43 AM   #5
There's a hole, but I don't know if it goes all the way through.
One does not simply remove the sticker. It's really on there, and won't go back on easily. So, if I remove it and there isn't a hole, no harm done (except that the sticker isn't nicely on), but if there is a hole, then surely I've affected Qms? But is this actually the right thing to do?
Old 21st January 2018, 07:46 AM   #6
Ok, I did an image search, and it looks like it's just a divet. The w250s doesn't have a similar sticker.
Old 21st January 2018, 08:18 AM   #7
You can use a long, thin needle and stick through the sticker.
Old 21st January 2018, 10:47 AM   #8
TBTL is offline TBTL  Germany
Visaton WxxxS series indeed do not have a vented pole piece.
Sticker on magnet over ventHide this!Advertise here!
Need a little help with a sticker timdandad Instruments and Amps 1 28th February 2017 08:32 PM
Push-push magnet rear vent question PeteMcK Multi-Way 5 20th August 2016 12:27 AM
magnet design 101 - saturate iron with a ferrite magnet? capslock Multi-Way 18 28th April 2010 04:51 AM
Driver has magnet vent, but not the dust cover? mikee55 Subwoofers 5 26th August 2008 11:43 AM
dampening noise from magnet vent Ignite Subwoofers 2 23rd May 2004 10:06 AM
