Mid and high range speakers
Old 13th June 2018, 10:15 PM   #41
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
I just looked up the JBL, and see it is a three way. I assumed it was just a tweeter with intergrated cap... that makes more sense now. Sorry I was not understanding the situation fully.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 14th June 2018, 06:37 AM   #42
gagashagy is offline gagashagy
Tony.
Hi, not an issue, my bad for not sharing all the details. So I understand correct, that padding this whole thing would be risky? I don't mind decreasing JBL woofers DB, since I have another standalone woofer, but I'm just worried about the resistor being overwhelmed. I can get 6.8 Ohm 100 W LPAD. This should be capable of handling the power? Maybe mount it on heatsink?
Old 14th June 2018, 06:58 AM   #43
Originally Posted by Mrcloc View Post
If you want to separate the JBL and the woofer completely, then you'll have to put a HPF on the JBL.
5.6 ohm + 2 ohm = 7.6 ohm. I think I remember that the woofer is 12 ohm, so ~8 ohm || 12 ohm is about 4.5 ohm, which your amp will be fine with.
I don't know how the integrated XO would react to additional HPF but this sounds like an option. I don't mind, if JBLs woofer would be shut off and JBL as whole, used only for mids and highs.
Old 14th June 2018, 08:07 AM   #44
just another
wintermute's Avatar
I think probably the best thing to do is just try the 5.6 ohm as Mrcloc has suggested, and see how it goes. You may find that the bass from the sub is too weak, but on the other hand the JBL will be running full range so should (provided there aren't big phase differences) augment the bass coming from the sub.
Tony.
Some of my photos
Old 14th June 2018, 09:54 AM   #45
just another
wintermute's Avatar
What is the value of the coil you wound? I'm putting some stuff in the simulator to get a rough idea of how this will work, but need to know the coil value
Tony.
Some of my photos
Old 14th June 2018, 11:05 AM   #46
Tony.
Value is 0.793mH rounded up to 8mH.
Old 14th June 2018, 11:08 AM   #47
just another
wintermute's Avatar
Thanks, Not sure how useful a sim will be but thought I'd see what happens
Tony.
Some of my photos
Old 14th June 2018, 12:15 PM   #48
just another
wintermute's Avatar
Ok So this sim is far from reality but it does show that you will likely still be reaching for the bass control (to turn it down!)
What I did was I simmed the woofer in the 10L sealed cabinet and exported the frequency response and impedance from that sim.
Then I created a curve for the jbl which is basically flat with a 2nd order butterworth roll-off at 100Hz. I used a completely flat 2 ohms impedance for the JBL which will not be realistic.
The fact the JBL is running full range means you get a BIG boost in the bass region, also because the JBL is only a two ohm driver the 5.6 series resistance drops it's sensitivity a lot. The overall impedance seems to be ok (but marginal).
The addition of a 68uF cap in series with the JBL allows dropping the 5.6 ohm resistor to 2.7 ohms, giving a much better result for both spl and impedance. I'm not sure however how this would interact with the existing crossover in the jbl, so I tried putting a 68uF cap in front of the crossover for my MTM that I have in vituixcad, and it pretty much just rolled off the bottom end leaving the rest of the response intact , So I think it would be worth getting a 68uF bipolar electrolytic to try it out. They can be had cheap enough 68uF 100V Electrolytic Non-Polarized Crossover Capacitor
Images of the sims attached. Last image compares my normal MTM response sim (black) to with a 68uF cap added in before the other crossover components (blue).
Tony.
Some of my photos
Mid and high range speakersHide this!Advertise here!
Speakers full-range with a high resistance. Svjatoslav Full Range 67 1st June 2018 01:15 AM
High quality floor standing speakers,full range plans for diy anyone have a link? nautilusdave Full Range 34 22nd February 2017 08:06 PM
Building a high pass filter / crossover for my small full range speakers Howard Full Range 3 24th October 2013 01:15 PM
How to build simple, cheap, high WAF, full range speakers scigu63 Full Range 15 6th June 2013 02:17 AM
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 03:46 AM
