Some speaker driver measurements...
Old 12th March 2018, 09:47 AM   #21
HiFiCompass is offline HiFiCompass  Ukraine
That is not the distortions of microphone at high measurements voltage levels and came from the driver itself. The measurement microphone B&K 4133 has much higher SPL overload level.
Old 21st March 2018, 05:30 PM   #22
The measurements of Peerless DA25BG08-06 have been added:
Peerless DA25BG08-06 | HiFiCompass
Old 29th March 2018, 04:53 PM   #23
The measurements of Peerless BC25TG15-04 have been added:
Peerless BC25TG15-04 | HiFiCompass
Very nice tweeter for that price
Old 19th April 2018, 10:43 AM   #24
Satori MW19P-4 midwoofer measurements have been added:
Satori MW19P-4 | HiFiCompass
Old 21st May 2018, 11:49 AM   #25
SEAS CA22RNY (H1471) woofer measurements have been added:
SEAS CA22RNY (H1471) | HiFiCompass
Old 28th May 2018, 03:18 PM   #26
BlieSMa T34B-4 beryllium dome tweeter measurements have been added:
BlieSMa T34B-4 Beryllium Dome Tweeter | HiFiCompass
Old 4th June 2018, 09:09 AM   #27
Audax TW034X0 textile dome tweeter measurements have been added:
Audax TW034X0 1.3" Textile Dome Tweeter | HiFiCompass
Old 4th June 2018, 12:49 PM   #28
TMM is offline TMM  Australia
Send a message via AIM to TMM
Thanks for the measurements
Have you considered equalising the response of the drivers to flat (or a reference slope) before running HD sweeps? It would help to make comparisons between drivers with different natural rolloffs. E.g. consider that the BlieSMa T34 is about 6dB down at 1kHz compared to >2kHz, which makes the distortion considerably lower at 1kHz compared to a tweeter which is flat down to 1kHz. Of course it is possible to look at the measurement which is twice the voltage to account for -6dB at 1kHz but I find it more intuitive if the levels are the same at every frequency to begin with, that way you can just open one plot for each tweeter and compare them side by side.
Up until now I've only been measuring midrange drivers which are more or less flat over their usable bandwidth so differing frequency responses hasn't been too much of an issue for me, but I'm planning to do woofers and tweeters soon and this seems like a big hurdle in comparing the distortion of different drivers as they near their mechanical resonances. I'm considering perhaps providing additional measurements with tweeters EQ'ed to 1kHz/2kHz LR2 and woofers to 40Hz BW2.
The solution seems obvious to me, yet for some reason no one seems to have ever done it.
Old 4th June 2018, 03:24 PM   #29
Sabbelbacke is offline Sabbelbacke  Germany
Thank you for the effort and publishing the data!
www.hornresp.net
Old 4th June 2018, 05:43 PM   #30
5th element is offline 5th element  United Kingdom
5th element's Avatar
As far as I know the measurements display the harmonics as relative to the fundamental, so that's already taken into account.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Some speaker driver measurements...Hide this!Advertise here!
Driver distortion measurements? maggiesnmacs Multi-Way 10 14th May 2016 06:28 PM
MA driver measurements tuxedocivic Full Range 67 13th April 2014 11:55 PM
Comparing REW, ARTA and CLIO in speaker driver and acoustic measurements panson_hk Equipment & Tools 28 9th April 2014 08:40 AM
Driver measurements Legis Multi-Way 0 12th October 2010 06:08 PM
Mic distance for driver measurements ted4412wilt Software Tools 5 17th December 2009 08:35 PM
