Wiring for both Passive and Active X-over
Old 17th January 2018, 04:35 PM   #1
almstsobur is offline almstsobur  United States
Default Wiring for both Passive and Active X-over
I'm just about getting to the wiring on my Statement ii speaker build. I have the components for the passive crossover and I have most of it built already. I also have a MiniDSP 2x8 that I would like to incorporate to try out an active X-over setup.
Please excuse my crude MS paint drawing, but this is more or less what I had in mind to keep things super simple. Basically the bottom 3 terminals are direct, always connected active crossover connections and the top are bi-wire/bi-amp H+M/W passive connections and a DPST toggle to break the connection to the passive X-over and speakers when I am using the active setup.
Does anyone see a better way to do this? I am trying to keep it very simple, I don't want to incorporate power, relays, or anything more than absolutely necessary. Does anyone see any problems with this, any effect on sound quality, or the like? I may need two toggle switches or more poles, I need to put this circuit together in my head a little better, but does the gist seem okay?
I appreciate the input.
Old 17th January 2018, 04:46 PM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
You want to bypass the passive crossover.
Or you just need the lowpass and /or the highpass of some sections and leave the lowpass and /or the highpass function performed by the Mini DSp
Everything under and above heaven is in utter chaos
mare monstrum
Old 17th January 2018, 05:08 PM   #3
I'd like it to be either or. Either all passive, which is Bi-wire Tweeters+mids and Woofer. Or all Active, Tweeter, Mids, Woofer on their own connection, the lower one.
Old 19th January 2018, 02:06 PM   #4
HaerdenC is offline HaerdenC  Belgium
Send a message via ICQ to HaerdenC Wiring for both Passive and Active X-over
I'm currently planning a build of speakers and had the same kind of question so what I will be doing is an alternative way of thinking ... I prepare my speakers with clamps for active crossover, the passive crossovers I ordered will be placed in an external casing :-)
If I ever want to go fully active I just wire to each amp currently I run old Marantz amps and use my external passive crossovers.
Old 19th January 2018, 02:39 PM   #5
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
If you want to use an active crossover, then the driver units must be directly to the amps.
Old 19th January 2018, 06:52 PM   #6
russc is offline russc  England
Except for a protection capacitor for the tweeter.
Old 18th February 2018, 12:10 PM   #7
Jollygreenaudiophile is offline Jollygreenaudiophile  United States
Jollygreenaudiophile's Avatar
If your system design is correct. And everything is in good working order you do not "need" a cap for the tweeter. And it just sounds better.
Wiring for both Passive and Active X-overHide this!Advertise here!
Basic Passive Sub Question (Wiring) guangui Subwoofers 16 8th March 2013 03:09 AM
wiring Q: adding amp to a Paradigm passive SB-100 grunt99 Subwoofers 1 2nd August 2012 03:29 AM
Wiring two passive crossover 3-way speakers in series olev Multi-Way 4 1st March 2008 07:37 PM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Passive External Crossover Wiring Duster Multi-Way 2 19th January 2004 10:01 PM
