Say you are going to build a really good 2 way with expensive drivers and you would like to compensate for baffle step without adding another expensive mid-woofer and you want to avoid an MTM configuration.
Find an inexpensive woofer that will provide the same low frequency performance and mount it on the rear of the enclosure. Add the necessary zobel and series inductor and voila!, an extra 6 db of output in the right frequency range without breaking the bank. Thoughts? |
#2 |
If you mount it on the rear therectically no c/o components are
needed at all, though normal BSC values will give rear radiation similar to front mounted drivers. TMM easily avoids the MTM configuration. MTM is only needed for 2 way with BSC implemented in the crossover. Usually IMO inexpensive woofers will compromise the bass quality of your expensive bass/mid unit. A variation on the theme is to go with a 6.5" sealed or overdamped reflex bass mid, and add a 8" reflexed bass. |
#3 | |
I agree with sreten. And wouldn't a different woofer have a different character?
KTK. Kool To the Kore. |
| thought you might want to know. | zuki | Subwoofers | 0 | 1st May 2007 05:07 PM |
| a thought | rlehman | Digital Source | 7 | 29th January 2003 02:50 PM |
| Thought of the day.. | Sawzall | Multi-Way | 11 | 28th June 2001 03:52 AM |
| Page generated in 0.07478 seconds (72.44% PHP - 27.56% MySQL) with 10 queries |
