What number and kind of speakers do you have at home
My list so far
Beyma 18G550 1 pc woofer
BMS 12N630 1 pc Subwoofer
Celestion CDX1-1445 2 pcs tweeter
ESS AMT 1 2 pcs tweeter
Focal 7K40 4 pcs woofer
Scan Speak 18W8545 3 pcs woofer
Scan Speak 26W Discovery 2 pcs woofer
Scan Speak 26W Classic 1 pc woofer
Scan Speak 10F 2 pcs fullrange
Scan Speak D9700/2905 2 pcs tweeter
SEAS 2 pcs woofer
Monacor Carpower 4 pcs coaxial
Monacor 10/250PRO 2 pcs woofer
Monacor 8/150PRO 2 pcs woofer
Monacor MVH 152 2 pcs horn
Mivoc 4W16 10 pcs woofer
Omnes Audio 4 pcs tweeter
Tangband 4W-1320 5 pcs fullrange
Tangband 6W-1916 2 pcs fullrange
Vifa 22 2 pcs woofer
Vifa 27D 2 pcs tweeter
Visaton BG20 2 pcs fullrange
Wavecor 315SW01 4 pcs woofer
Best regards
Uwe
Nice list.
In use:
2 Fane Sovereign 12-250TC (closed, 110-18000hz).
2 the box Speaker 12-280/8-W (ported, 55-110hz, soon to be 6th order bps).
1 Alpine SWG-1244 (6th order bandpass, 30-55hz).
Lying around, soon to be used:
2 Fane Sovereign 12-250TC.
2 the box Speaker 12-280/8-W.
4 Alpine SWG-1244.
In use:
PA system:
- 18Sound ND1460
- Faital Pro 10FH520
- Faital Pro 15HP1060
- Beyma 15P1200Nd (within 1dB of the Faital 15"s - I use them interchangeably)
- P-Audio SD21-1800N. Mounted in a sealed box, goes out for rentals with a couple of small main speakers.
Home:
Modified Behringer B3030A for mains, sometimes a 16" cube with 2x JBL GTO1214 for sub use.
Lying around:
16x Bose 2.5" full-range units, used in early iPod docks. Sound pretty good, working on a portable line array.
2x Fostex FE126E with full P10 treatment
2x Fostex FE166En
2x 18Sound 6ND430
Chris
Which one do you prefer sq-wise?
Haven't auditioned them one vs the other, only done some measurements where (as Hornresp predicts) they're extremely close. They reach their limits at about the same time when you hammer them with a MA12000i, too. Not much to choose between them, really.
I use them for live sound, so moving the kick drum mic 6" makes a bigger difference to the LF sound quality.
Chris
In use
Monacor SPH 30X desktops with chip amp
Alpair 12PW and Viawave RT850 transmission line (90% finished)
SB 6.5" Nac and Viawave GRT145 standmount
Alpair 7.3 mini transmission line (total failure)
List of drivers (some in and out of cars or half built projects)
TLab Be tweeters
Scanspeak HDS tweeters
Scanspeak Revelator 5.5 undoped
SB satori MW16p-8 2 pairs
SB satori MW13p-4
Scanspeak 26w discovery 8 ohm
Peerless HDS 6.5" alu
Alpair 10p 2 pairs
TB 2" W2 800SL
Dayton ES180ti 10 pairs
Viawave rt850 spare pair
One bandor 50.. lost the other one!
All self built.
Fane 12-50WRMS in a folded horn cabinet.
2 off Fane 10-300WRMS in folded horn cabinets.
1 off Fane 15-600WRMS in a folded horn cabinet.
2 off Fane 12-250-TC's in a sealed cabinet.
4 off Fane 10-125WRMS in a sealed cabinet.
1 off Fane 12-500WRMS in a bass cabinet.
1 off Fane 15-400WRMS in a sealed cabinet.
2 off Fane big cat 12-100WRMS in a sealed box.
For home use,
52x Vifa TC9
2x Scan Speak 10F
2x Scan Speak 30W
Of the above list 50x Vifa and 2x Scan speak 10F are in use... the 2x Scan Speak 30W will soon be added to the in use list, meaning I only have 2x Vifa TC9 laying around for future use and/or experiments :).
My goal (and hobby) is to get the best out of what I have, not to build as many variations as I can. I got tired of trying out many different drivers. I don't think that's where the answers are to my particular questions.
Can not stop bying drivers
Hi
I can not stop bying new drivers.
Most of the ones I have have never been out of the box. I have a lot of ideas but not enough time and/or energy to try them all out.
That said I have 5" TB fullrange and 2 vifa 8" for home cinema.
I have the PA stuff for my mobile discotheque.
And I have some of the Scan Speak and the Focals for stereo.
Next project is a baffle less three way speaker for stereo. Wavecors for bas, ESS for highs and and will experiment with all of the drivers that can handle the midrange.
best regards
Uwe
PS me and drivers is a little like my wife and shoes/handbags etc.
Uwe/Heinz1964, i totally agree with you about cannot stop buying drivers...
I've just cleared over 2 dozen drivers I won't be using... so the list is pretty much trimmed down
[Living room high eff speakers, WIP]
JBL 2435HPL 1.5" + JBL M2 waveguide
Acoustic Elegance TD15M-8A 15"
Acoustic Elegance SBP15-8 15" (2 pairs)
[Living room 2nd speakers, Rinjani Kit]
SB Acoustics Satori TW29 Beryllium
SB Acoustics Satori MW16P Midwoofers (2 pairs)
[3rd system, with inlaws, Troels Gravesen's Jenzens TL]
Seas Excel E0006
Seas ER18RNX
Seas CA26RFX
[Study Speakers, Ara kit]
SB Acoustics Satori TW29R Tweeters
[Wife's Speakers, WIP]
Scanspeak Revelator 9900 1.1"
Scanspeak 15W8530K00 5.25" (3 pairs)
[Potential cheapy large build?]
JBL 2226H Clones (2 pairs)
[Another home audio reference system?]
Beyma TPL150H AMT Tweeter
ATC SM75-150
Acoustic Elegance TD10S-8A
[Bwaslo's design, in storage]
B&C DE250 + SEOS15
Acoustic Elegance TD15M-8 15"
[Linkwitz Pluto 2.1]
Aurasound 2"
Seas LR16
Peerless SLS 10"
[Spare Drivers]
Usher 9950-20 tweeters
CSS L25DX tweeters (XBL^2 Motor) 3 pairs
Seas T27TDFC 1.1" in MCM waveguide ala Zaph Waveguide TMM
Vifa TG9FD (2 pairs)
Coral Flat-6 II
Coral Flat-10 II
Fountek FW168 6.5"
Fountek FW146 5"
Hivi D6.8
Vifa 490-001-00
Peerless 830656
Peerless PR830880
Peerless 830862
DIYSoundGroup SEOS8
Pellegrene Acoustics Custom for Satori TW29
SB Acoustics SB29NRX75-6
SB Acoustics SB29RDNC Tweeter
SB Acoustics SB15NRX
SB Acoustics SB15BNAC
SB Acoustics SB17CAC
Grouped by speaker systems:
BMS 4550 on a QSC waveguide
Peerless 830869
BMS 4540ND on JBL 6" PT waveguide
Fostex FF125K
Fostex FF85WK
Tang Band W4-1320SIF
Faital Pro 6FE100 (two in a single monophonic setup for garage tunes)
Eminence APT80 (only one in that same enclosure)
That list would have been 3-4x as long a few years back, but it's good to cull the herd and only keep what's in actual use.
Believe it or not, I'm down to 1 active pair & woofers upstairs, the 7.1 (dual woofers) downstairs, and only 1 spare pair. Mr D, on the other hand - not counting inventory staged for treatment - must have literally hundreds, I'm sure he's not tallied them for years.
