High performance 1" Compression drivers/waveguides for HiFi Loudspeaker Project
I am looking for small format Horn Flare and compression driver recommendations for a loudspeaker system I am working on, the crossover point will be around 3.5 - 4 Khz
Midrange driver is the Volt VM752 and the bass is the Volt RV4564.
Initially I am looking at a horn flare such as this B&C ME20
There are plenty of HF drivers available, but again I need to strike a balance between performance and HF extension.
Much to investigate!!
