4" midwoofer for mini 2 way
Old 13th January 2018, 11:14 AM   #11
Mario Pankov is offline Mario Pankov  Europe
Monacor have a 4" midbass which goes amazingly deep and works well in a small box but has limited output, 84db/1W. If it fits your bill, have a look at it, SPH-100C. Although small, I wouldn`t cross it above 2Khz, ideally to a fullrange much lower.
Old 13th January 2018, 11:17 AM   #12
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Originally Posted by akarma 76 View Post
Yep. But dip in 2KHz region looks not so good.
Its no deal breaker imo and sufficiently close to x/o in most cases.
Old 13th January 2018, 11:56 AM   #13
Zvu is offline Zvu  Serbia
Zvu's Avatar
These looks good also:
Dayton Audio ND105-8 4" Aluminum Cone Midbass Driver 8 Ohm
Dayton Audio CF120-4 4-1/2" Woven Carbon Fiber Midwoofer 4 Ohms
Not for fainthearted
Old 13th January 2018, 12:59 PM   #14
akarma 76 is offline akarma 76
Dayton Audio ND105-8 looks like more as a miniwoofer with pretty low sensitivity. I forgot to say but i wll be using speakers with subwoofers. So i don't need extra bass from satellites. 80Hz will be enough.
So Dayton RS125 vs SB12PAC25. Any opinions ? 53-54/pair vs 41/pair.
Old 13th January 2018, 03:02 PM   #15
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
Honestly, I think the HiVi M4N might suit your box size better. They have a higher Qts, and I used them in a 4.5ltr stuffed/ported box to reduce the ripple and improve the response. If you run them sealed/stuffed, you'll likely get about what you desire.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 13th January 2018, 03:49 PM   #16
I've thought about HiVi B4N too. Qts is high enough for sealed box for shure. Sensitivity is 80Db. Cheap. How do you like HiVi M4N? Do you have real experience with any mentioned drivers above?
Old 13th January 2018, 07:06 PM   #17
adason is offline adason  United States
adason's Avatar
Hello guys!
I have some speaker's cabinets and want to make budget mini 2 way monitors. Volume is about 4L. I consider right now some 4" speakers for use in that project:
- midwoofers Dayton RS125-4 (8), Dayton RS125P-8. I would be grateful for the feedback from those who had the opportunity to compare them. For a long time I wanted to but never used speakers with metal cones.
Also consider SB12PAC25-4. There are not many reviews. Cheap. The parameters are also good. But plastic basket is ugly.
On HFreaquency I consider DAYTON ND25FA-4 and ND28F-6. I have not decided yet. Because of the cabinet, a tweeter with a flange diameter of 66-75mm is needed.
Rs125 aluminium cone drivers are excellent...
Old 13th January 2018, 07:13 PM   #18
adason's Avatar
The notion that metal cone drivers sound metallic is utter nonsense. Rs125's are flat, neutral and balanced. Very low distortion, pure hifi. Small resonance at ~10k is no issue as its quite far up and easily removed. Plus they go quite deep for such a small driver. They can practically cover very large range, say 150 to 3000 hz, which is beneficial.
Highly recommended.
Old 13th January 2018, 07:15 PM   #19
adason's Avatar
Zaph|Audio
Old 13th January 2018, 10:48 PM   #20
boswald is offline boswald  United States
I'm with Ed on this. I've been running one rs125-8 and one rs125p-8 to see which I like better, and I like them both.
Easy to work with.
4" midwoofer for mini 2 wayHide this!Advertise here!
FS: JBL 2035 15" Midwoofer and 2446j 2" CD with waveguide/bracket assembly. bikinpunk Swap Meet 0 7th June 2017 03:20 PM
Which 6.5" midwoofer for this project? Bill poster Multi-Way 10 3rd March 2014 01:46 PM
6,5" to 7" midwoofer for sealed enclosure martinbls Multi-Way 93 26th September 2012 11:22 AM
RSC (radio speakers canada) 15" woofer, 8" midwoofer, horn tweeter perceptionchanges Swap Meet 0 29th May 2010 07:18 PM
