DIY speakers for Audio(phile) Cafe Bar...Need help and support!
Old 9th January 2018, 06:24 PM   #11
manninen is offline manninen  Finland
manninen's Avatar
copy Legis set, just double the size under 40hz
Old 9th January 2018, 06:30 PM   #12
Zvu is offline Zvu  Serbia
Zvu's Avatar
Originally Posted by zmyrna View Post
yep, have been watching all of that
but my favorite one is in Korea (ignore the music) YouTube
Well that's one more way to do it
Not for fainthearted
Old 9th January 2018, 06:35 PM   #13
zmyrna is offline zmyrna  United Kingdom
link please
Old 9th January 2018, 06:38 PM   #14
johnnyx is online now johnnyx  United Kingdom
Would the sound system double up as a PA for live musicians, occasionally?
Old 9th January 2018, 06:38 PM   #15
manninen's Avatar
Legis' Horny Tales
not much left cause photobucket
Old 9th January 2018, 06:42 PM   #16
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
I would use a couple of Fane Sovereign 12-250TCs (in multiples of 2), subs and a dsp.
Easy, effective, inexpensive and good enough.
Old 9th January 2018, 06:50 PM   #17
if possible, yes...
but not a requirement...
one can easily set up a secondary PA for live shows.
Old 9th January 2018, 06:50 PM   #18
adason is offline adason  United States
adason's Avatar
Yes!
This is what I would do if I was to build great sounding 4-way speakers:
I would select some good tweeter, say RAAL or Beyma tpl150, or any other...then I would select upper midrange, not too big, it has to be ~6" to go high up to the ribbon, my choice would be 6fe200, great mid up to 5kHz with no breakups...then I would get some pro woofer, say 12", efficient, with minimum breakups, plenty of them to choose, especially faitalpro, finally some 18" woofer.
This would not necessarily have to be active, I would split the signal for woofer, use plate amp to power it, and send upper part of the signal to separate amp and make rest passive. That way it would be easy swap stereo amps for fun.
Good luck with the jazz café idea.
Cheers!
Old 9th January 2018, 07:09 PM   #19
Originally Posted by manninen View Post
Legis' Horny Tales
thanks for the link.
i was considering multiple 18" tapped horn or PPSL for subwoofer duties.
PP tapped TL = why not?
where can I get the drawings?
and I took note of synergy/unity horns; especially for a smaller venue, right?
Old 9th January 2018, 07:17 PM   #20
Originally Posted by adason View Post
Yes!
This is what I would do if I was to build great sounding 4-way speakers: <snip>
Adason, I have been following your 6FE200 thread; I like the idea very much. I have been thinking of 4x 6FE200 arranged in a square with a bullet tweeter in the center; quasi co-axial. My only worry is lobing.
DIY speakers for Audio(phile) Cafe Bar...Need help and support!Hide this!Advertise here!
Where’s Café Blue? Peterm100 Music 0 26th December 2017 07:39 AM
LC Audio is not responding with support BMW850 Class D 3 25th November 2010 02:01 PM
Frugal-phile(tm) jag Everything Else 36 22nd July 2008 02:46 AM
Noticed that Nero ULTRA 7 Support 192KHz Audio alvaius Digital Source 0 21st January 2006 05:03 PM
Listening for jitter, s'phile test CD2 - ??? Matt MacBeth Digital Source 15 12th November 2002 11:30 PM
