Opinions on Pairing Satori MW19PNW-8/AMTPRO-4?
Old 5th January 2018, 01:04 PM   #11
glenv6 is offline glenv6  United States
Originally Posted by sun12 View Post
And how does this dayton sound like a midrange or like a twitter spooky?
Can you record the sound to hear how it sounds?
I also look at him.
It is going to be a awhile, sure, I can record the sound once I have my speakers built.
Old 5th January 2018, 01:07 PM   #12
Originally Posted by TNT View Post
The Satori is great upwards. Try to find if there is a frequency where both drivers have the same dispersion pattern at 30 and 60 deg. Above 2k.
Okay, I will do that - Thank you! I am going to order the Satori drivers today.
Old 5th January 2018, 01:15 PM   #13
Originally Posted by Lojzek View Post
You can have these traced from a spec sheet and assumed on a baffle 22x45 cm. Vented box tuned to manufacturer's suggestion.
This is great, thank you!!
Would you mind elaborating on the process used to trace from a spec sheet? How is the baffle size and vented box tune used when deriving data from the spec sheet?
Old 5th January 2018, 02:55 PM   #14
Ah, found the way to derive those files from screenshots of the response graphs.... I found SPL Copy app here:
SPLCopy.zip - Google Drive
Old 5th January 2018, 04:05 PM   #15
LineSource is offline LineSource  United States
LineSource's Avatar
Expert designer Troels Gavesen built the MW19 Studio Monitor using the MW19P-8 and selected an LR4 circuit at 1700Hz for the crossover.
"The MW19P-8 midbass driver used here is a rather large driver having a radiating area of 158 cm^2, a little bigger than the ScanSpeak 18WU drivers. Due to size of the midbass we need a low point of crossover to the tweeter ... Here we go with a point of crossover at 1700 Hz providing the best possible frequency response and we use an LR4 filter (circuit) providing some added presence in upper mid/lower treble despite the large cone area of the midbass. By using a steep filter we reduce the "echo" of the midbass beaming. "
I use passive LR4/LR4 cricuits at 1650Hz with the MW19P-4 midbass and SB29RDC-04 dome for TV/desk speakers.
Old 5th January 2018, 04:19 PM   #16
TNT is offline TNT  Sweden
Oops, I thought we where discussing SATORI MR13P-4.
Sorry.
More distortion to the people!
Old 5th January 2018, 05:34 PM   #17
CharlieLaub is offline CharlieLaub  United States
Hey There!
I just purchased a couple of AMTPRO-4s on sale from Parts Express and I'm looking for drivers to pair them with. My thought is a two-way with the Satori MW19PNW to keep it simple. Crossover would be an LR2@1500hz on both the low pass and hi pass.
Would this be a good pairing? Is 1500hz too low? Too high? The MW19PNW dips about 2db around 1200hz. Does that rule out this pair? Or, would I need a different x-over point, or can I work with the dip electrically to smooth it out?
Thanks in advance
The AMTPRO-4 frequency response makes it less than ideal about 10kHz. I attached a measurement I took on a unit that I own, in free air. It might be possible to EQ the response so that you get a smooth transition between the mid-passband level of (on my plot) 105dB and the near 10kHz response level of 100dB - you might want to EQ out the "hump" around 10kHz or it could sound fatiguing. I would probably try this approach with an active DSP crossover, however, because you might need to combine several EQ bands to get it right.
The AMPPRO-4 also has a rather "tall" diaphragm for a tweeter. The size of the diaphragm is especially a problem in the vertical plane, where the response pattern starts to narrow starting at 4kHz. You can use it as low as 1.5-1.8kHz (it will need a back enclosure). If you add a small dome tweeter (e.g. Ox20?) crossed over at 5-7kHz you will get better overall performance from 5kHz to 20kHz.
On the plus side, the distortion signature is pretty clean and efficiency is high. It's a good driver when used in a way that minimizes some of the response issues.
Note: If you have advanced hearing loss you might not notice the issues above 5kHz I mentioned since these are getting near the edge of your ability.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 5th January 2018, 05:48 PM   #18
mlee is offline mlee  Canada
Agreed! I always use something above the AMTPRO-4 even when eqed flat. Seems like it is missing that something over extended listens.
Think before you speaker!
Old 5th January 2018, 06:59 PM   #19
Sorry.
eee MW16P-4 was the driver I had i mind.
Old 6th January 2018, 02:11 AM   #20
Thanks for finding this, I checked out the build on Troels Gavesen's website. If the AMTPRO-4 doesn't work out, I may end up with a Satori tweeter instead. Too bad the component values of the crossover aren't listed.
Opinions on Pairing Satori MW19PNW-8/AMTPRO-4?Hide this!Advertise here!
tweeter integration with Dayton AMTPRO-4 CharlieLaub Multi-Way 32 25th March 2018 07:41 PM
Dayton AMTPRO-4: how low to cross when used open back? CharlieLaub Planars & Exotics 8 10th March 2017 02:43 PM
Dayton Audio AMTPRO-4 Air Motion Transformer Tweeter Pair For Sale gfederys Swap Meet 2 2nd November 2015 10:09 AM
Pairing? solly98 Multi-Way 0 28th November 2012 12:15 AM
vifa pairing rv1890 Multi-Way 2 25th January 2005 07:21 PM
