Best waveguide under 17.75x6.75" mouth for The Selenium D220Ti
Old 16th May 2018, 08:18 PM   #41
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Unfortunately a screw-on type, but this caught my eye (just for the size and price). Also clearly not constant directivity (something that I do like myself)
TE-8180 1" Horn 22.5" x 10" 1-3/8"-18 TPI
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 16th May 2018, 09:46 PM   #42
Godzilla is offline Godzilla  United States
Godzilla's Avatar
>>> I happen to really like "zillas" blog due to his lack of simply parroting half-baked internet "truths" ( that we must all like "cd directivity uber alles" ).
Many thanks, EarlK! Your assistance was instrumental in my enjoyment! It will be difficult to go back to typical dome and cone tweeters since enjoying CDs plus waveguides. They offer amazing dynamics and clarity in a home environment.
Question for the group... are we all agreeing that a 1” cd plus appropriate waveguide works well with a 15” woofer in a home setup?
Old 16th May 2018, 10:18 PM   #43
turnitdown is offline turnitdown  United States
Well, it DOES look like the Emilar a bit. Those are kindo' pricey if you find them tho. I'm slogging my way through two building and speaker testing books and Wayne's paper on crossovers, so for the price of a couple of cheap wave guides - we'll call it research. I have the test setup complete, so time to jump in.
Old 16th May 2018, 11:25 PM   #44
Michael Chua is offline Michael Chua  United States
Michael Chua's Avatar
Originally Posted by turnitdown View Post
... my large and small JBL butt cheeks (2342 & 2344) ...
The JBL 2342 is a nice horn. No problems with a JBL2425 CD. Did a 2-way with an 8" HiVi M8a.
Click HERE for more info.
ampslab
Old 16th May 2018, 11:30 PM   #45
That horn is as wide as my JBL2345.
ampslab
Old 16th May 2018, 11:43 PM   #46
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Originally Posted by Godzilla View Post
.. are we all agreeing that a 1 cd plus appropriate waveguide works well with a 15 woofer in a home setup?
For small room I preferring 1.4" (1.5") cd
flesh flash flush
Old 17th May 2018, 12:29 AM   #47
Yes, 4430s here and 2342s with 2417s (lighter diaphragm, good highs) sitting over LE14H-1s. I have all the parts for another 4430 but might hold out for a pair of 2234s to build vertical 4435s.
In the meantime, I build with whatever I can get my hands on, so new products or newly discovered horns interest me. The H812s look interesting so I'll check them out when they arrive.
Old 17th May 2018, 12:35 AM   #48
The Blackbirds look fun. I LIKE 'em.
I just sanded a pair of boxes and built the crossovers for a pair of vertical 4612 Cabaret clones. Imagine them bi-amped so I can run LE14As for the bottom! Just came in from the garage doing that.
Looks like I can put a finish on them, install the drivers and fire them up this weekend. I'll pull these out to poolside for a little fun. Getting warm (but rainy right now) here.
Old 17th May 2018, 03:12 AM   #49
Thanks. Glad you like them.
I would like to make two versions in future. One with a 10", possibly a JBL 127H and the other a 12", a Dayton PA310. I have these woofers in hand so it's just a question of building the boxes.
The 4612 looks interesting. I'm a fan of two 8".
I wasn't aware that the JBL2404 goes down to 3kHz. I happened to have a pair as well as the Peavey HT94.
Good excuse to put them to good use.
ampslab
Old 17th May 2018, 10:51 AM   #50
mrk7 is offline mrk7  Australia
mrk7's Avatar
I don't know about 'all' but it is working pretty well for me at present (QSC waveguide/B&C DE250 CD/AE TD15M woofer passively crossed and massaged with EQ/room correction and accompanied by additional subs).
Previously had the QSC/DE250 combo crossed to cheapish 12" PA woofers using an Econowave crossover plus EQ. That combo worked great too and offered excellent bang for buck.
As long as the waveguide supports a low crossover point and matches the dispersion of a 15" woofer (like the QSC does) all should be good.
Best waveguide under 17.75x6.75" mouth for The Selenium D220TiHide this!Advertise here!
FS: Selenium D220Ti 1" Titanium Horn Driver 8 Ohm jazbo8 Swap Meet 1 15th April 2017 05:07 PM
FS QSC waveguide with Selenium D220Ti driver and extra 16 ohm diaphragm dubwoofer Swap Meet 3 6th November 2015 10:05 PM
Selenium D220Ti drivers boudy Swap Meet 1 24th May 2013 01:26 AM
What's wrong with this Selenium D220Ti? keyser Multi-Way 10 1st June 2011 09:56 AM
Dayton 10" waveguide and D220Ti Andrew Eckhardt Multi-Way 7 17th December 2010 12:03 AM
