Best waveguide under 17.75x6.75" mouth for The Selenium D220Ti
Old 11th May 2018, 06:55 PM   #11
Godzilla is offline Godzilla  United States
Godzilla's Avatar
I never heard the Selenium compression driver but can offer these comparisons. Honestly, I think you might need a 1.4 or 2 inch compression driver to match well with a 15 inch woofer. The tweeter really should get below 1kHz.
Perhaps consider one of these?
Eminence N314T-8 1.4" Neo Compression Driver 8 Ohm 4-Bolt
With one of these:
FaitalPRO LTH142 1.4" 60 x 50 Elliptical Tractrix Horn 4-Bolt
Eminence H14EA 1.4" Cast Aluminum Exponential Horn 60x40 4-Bolt
FaitalPRO HF144 1.4" Neodymium Compression Horn Driver 8 Ohm 4-Bolt
Here are my listening (and very amateurish) measuremnt tests.
Waveguide Comparison using Dayton Audio DT250P | Speaker Projects by Zilla
https://speakerprojects.wordpress.co...us-waveguides/
https://speakerprojects.wordpress.co...enium-hm25-25/
Old 11th May 2018, 07:26 PM   #12
ScottG is offline ScottG  United States
I'm assuming a bolt-on version of the Selenium (not screw-on)..
Denovo Audio SEOS-15™ for dome tweeters
..ask when it will be back in stock.
-and a backup solution:
RCF H100 1" Horn 90x75 3/4-Bolt
..and for a lot more money and (generally) requiring a supertweeter, with more low-end extension: AH-550
Azurahorn -Le Cleac'h Acoustic Horns - Products
perspective is everything
Old 11th May 2018, 07:53 PM   #13
..preferable 1" exit compression driver:
Peerless by Tymphany DFM-2535R00-08 1" Compression Horn Driver 2/4-Bolt 8 Ohm
Old 11th May 2018, 08:22 PM   #14
..oops, didn't meet the vertical limitation.
Old 11th May 2018, 08:34 PM   #15
StainlessSteve is offline StainlessSteve  United States
StainlessSteve's Avatar
I do have the screw-in drivers.
Old 11th May 2018, 08:50 PM   #16
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Originally Posted by hweb View Post
The venerable QSC waveguide (no longer available) is awesome. This one: B-52 PHRN-1014 1" Horn 10" x 14" Bolt-On appears to be identical. It should unload at around 1050Hz. The PH612 should unload at around 1400Hz, so if you plan on mating this with a 15" woofer you might prefer the larger waveguide.
That does look like a QSC clone, and if so is one heck of a nice waveguide. (It isn't, btw, in any way an "exponential horn" as it says in the listing! It's a conical with an oblate-spheroid-like throat). Years ago I made a 2-way with the bolt-on D220Ti and a Large Advent woofer -- it was one of my favorite speakers, still in use at my son's house. It sounded a LOT better to me than the original Econowave (JBL designed) horn, not sure if that had to do with the bolt-on driver vs. the screw-on one of the JBL. The QSC horn also works really well with that Tymphany driver mentioned elsewhere in this thread (I'd toss your screw-on Seleniums in the bin and get a couple of the Tymphany's if I were you..... but then I hate screw-on compression drivers because of that inherent straight pipe section).
I have several of the QSC clones here, for whatever reason, but I'm still tempted to pick up some more of these buyouts "just because".
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 11th May 2018, 09:01 PM   #17
..probably better off making your own straight-side horn in the dimensions you want, otherwise you won't get the extension you want in the form-factor you demand.
(aka: to many limitations and no reasonable commercial solutions.)
Old 11th May 2018, 09:40 PM   #18
Anyone wanna buy two Selenium D220Ti's?
Old 12th May 2018, 01:21 PM   #19
Godzilla's Avatar
Goldwood GM-500PB 1" Horn 1-3/8"-18 TPI
In the comments someone mentions using these with the Seleniums. They are similar in size to the 15 inch SEOs previously mentioned. Depending on your budget they might be worth considering.
Old 12th May 2018, 02:22 PM   #20
turnitdown is offline turnitdown  United States
I am a huge proponent of the Econowave and the Selenium is a proven winner on the JBL/Pyle wave guide. If you build that, you will be pleased.
First, Wayne Parham uses a 15" 2226 to meet the HF element. It has slam and mid range that is true to the source material. A 15 to a 1 inch works. Now...
keeping that thought in mind, the econowave loses nothing if you're using a good 15" mid/woof. The econowave features an asymmetrical crossover. The mid/woof has to play well up to about 1200 but the crossover to the horn is much higher. The mid/woof signal is decaying while the horn/CD is coming in. The crossover acoustical point is around 1360 while the electrical crossover points for each driver are different - but they blend well in the middle frequencies. Beam width on both drivers is very close at the actual crossover point.
There are then avenues open to upgrade as you see in various places, but the crossover and the concept are proven as demonstrated by the number of these that were, and are, being built.
That being said, if this is your first build, or first horn build - try it. You have the parts and it fits your requirements.
Best waveguide under 17.75x6.75" mouth for The Selenium D220TiHide this!Advertise here!
FS: Selenium D220Ti 1" Titanium Horn Driver 8 Ohm jazbo8 Swap Meet 1 15th April 2017 05:07 PM
FS QSC waveguide with Selenium D220Ti driver and extra 16 ohm diaphragm dubwoofer Swap Meet 3 6th November 2015 10:05 PM
Selenium D220Ti drivers boudy Swap Meet 1 24th May 2013 01:26 AM
What's wrong with this Selenium D220Ti? keyser Multi-Way 10 1st June 2011 09:56 AM
Dayton 10" waveguide and D220Ti Andrew Eckhardt Multi-Way 7 17th December 2010 12:03 AM
