RAAL ribbon with 4" midbass computer monitors
Old 3rd January 2018, 08:02 PM   #11
ScottG is offline ScottG  United States
for reference, high-pass filter in-place as seen on second amplitude graph/picture:
New Raal 64-10 ribbon?
I'm guessing an Audax HM100Z0 mid (depending on diffraction sig.) + a more efficient midbass driver..Dayton Audio PM180-8
perspective is everything
Old 3rd January 2018, 08:39 PM   #12
mlee is offline mlee  Canada
Hi Flaxxer,
How far down the rabbit hole did you want to go? If you want to do passive crossovers REW outlines an impedance box that can be used to measure a drivers impedance over frequency (cost is minimal). Armed with this and a mic you could use the very good xsim program (free) to create crossovers.
If you could make a few measurements and post them to the forum, their are a number of people that could help come up with a crossover that would work but some learning curve is involved.
Requirements:
1. Choose woofer. Wideband fullranger might be good just in case things start to get hard.
2. Build impedance box.
3. Build enclosure, get the mid and tweeter spaced as close a possible.
4. Measure drivers impedance and frequency in enclosure and post to forum.
If you don't want that hassle of the above, pick a fullranger and do first order crossover around 5khz? Play with the tweeter polarity, one way will have a higher perceived tweeter level than the other, use that polarity. Then set tweeter level as per taste.
With that nice tweeter it would be great to do it justice though and create your first 2-way speaker! If you don't want to monkey around with an enclosure the parts express cabs are nice and you can probably get free shipping.
Think before you speaker!
Old 3rd January 2018, 09:56 PM   #13
Zvu is offline Zvu  Serbia
Zvu's Avatar
That little Audax could measure better. I really don't like the ridges in waterfall:
AUDAX HM100Z0 (Mid-range 4", 8 Ohm, 80Wmax)
While the W4-1337SDF is somewhat better in that regard, but lower sensitivity:
TB SPEAKERS W4-1337SDF (Full-range 4", 8 Ohm, 50 Wmax)
Not for fainthearted
Old 4th January 2018, 02:20 AM   #14
The ripple's not bad for something that will be down in pressure almost 9 db before the ripple begins (..with a net 4th order LR). (..assuming 3.1 kHz for the crossover.) Decay before then is very nice and excepting the ripple and its consequence with decay, is still rather good at higher freq.s..
Even the directivity loss for the Audax mid. between 2-4 kHz should sum reasonably well with the tweeter.
Old 4th January 2018, 02:24 AM   #15
Originally Posted by Zvu View Post
While the W4-1337SDF is somewhat better in that regard, but lower sensitivity..
..and that's the problem.
On top of that there is the issue with respect to baffle diffraction - assuming a small box the rising response of the Audax usually results in an easier crossover. (..flat response is great for a wider baffle though.)
Old 4th January 2018, 04:21 AM   #16
Flaxxer is offline Flaxxer  United States
The xover is actually 3.4k. RAAL shouldn't cross lower.
Old 4th January 2018, 04:50 AM   #17
I'm looking at Zvu's actual measurement with cap. ref. of 4.7 uf on 8 ohm tap.
-6db from average looks like 3.1 kHz to me.. how about you?
..and remember, we aren't talking about the high-pass filter of the ribbon (which we assume is set by the recommended 4.7uf cap) - rather the high-pass filter of the mid..
Old 4th January 2018, 06:10 AM   #18
Oh, ok. Understood now.
Old 4th January 2018, 08:25 AM   #19
Zvu's Avatar
The crossover point should be arround 3.5KHz. There are 2 ridges, one just bellow 2KHz and other is the main breakup. I am not worried about amplitude but about time domain because it rings only 9dB bellow fundament lasting almost 3 times longer than other frequencies in the pass band. If we are looking at distortions that are -40dB as relevant, why should we avoid to look at resonance ridges the same way - and they are much more detrimental to the sound.
Old 4th January 2018, 08:32 AM   #20
Zvu's Avatar
Why would lower sensitivity be a problem for computer monitors, that op said he wants to design ?
If easier crossover is the one with less components, than i say - it depends.
I measured it's response in that small loudspeaker with recommended crossover just to see what Aleksandar wanted for us to hear. I listened that way for some time, then i changed it.
RAAL ribbon with 4" midbass computer monitorsHide this!Advertise here!
RAAL 70-10D RAAL Ribbon Tweeters thim Swap Meet 11 17th December 2013 04:11 PM
AudioTechnology + RAAL Ribbon = "Sequence Three Grand Reference" gornir Multi-Way 69 15th July 2013 08:48 PM
RAAL 70-10D Ribbon Tweeters sunandmoon Swap Meet 2 26th September 2011 08:36 PM
WBT: RAAL Ribbon b3s Swap Meet 3 26th December 2009 11:58 AM
FS: very nice RAAL "FlatFoil" ribbon tweeters {NIB }, with custom made front plate yairf Swap Meet 3 2nd June 2009 09:25 AM
