Bookshelf Suggestions
Old 31st December 2017, 05:52 AM   #1
Roo2 is offline Roo2  Australia
Default Bookshelf Suggestions
Hello there,
I'd like to build a pair of 2-way bass reflex bookshelf speakers and I'm looking for your driver suggestions.
I've a little bit of experience designing and building with the "Loudspeaker Cookbook".
I'm particularly seeking your low-medium cost woofer make/model suggestions. I'm thinking 6.5"-7" diameter to keep the enclosure size reasonable and still give me some bass.
I have a pair of unused Vifa D25AG-35-6ohm tweeters left over from an old project. It would be good to use them but if you can suggest some modern low cost alternative that will outperform them then please do so.
Fire away!
Thanks,
Andrew.
Old 31st December 2017, 07:03 AM   #2
bbe22 is offline bbe22  South Africa
this should work nicely with your Vifa tweet...
DSA175-8 61/2" Designer Series Woofer Speaker - Dayton Audio | Wagner Online Store
Old 31st December 2017, 07:55 AM   #3
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
This is probably the best buy at the moment.
Peerless PPB 830874 - 6.5" Poly Cone Woofer
edit: I have built one. Post #2568.
System Pictures & Description
A good dialogue makes you feel like a changed person, not like you have won or lost the competition.
Old 31st December 2017, 08:00 AM   #4
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Peerless by Tymphany 830875 6-1/2" Nomex Cone HDS Woofer
Old 31st December 2017, 08:30 AM   #5
Shipping from US to OZZ might be costly
Old 31st December 2017, 08:44 AM   #6
Maybe there is a local dealer somewhere.
Old 31st December 2017, 06:35 PM   #7
PeteMcK is offline PeteMcK
Local Dealers - Wagner have SB, Peerless, Vifa, Scanspeak
Loudspeaker Kit have Dayton
Soundlabs have Visaton & some Wavecor
Best Value in Oz is probably this SB driver, $15 cheaper than the Peerless:
SB17NRXC35-8 Sb Acoustics 6.5” Mid-Woofer - Nrxc, Speaker Drivers | Wagner Online Store
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 31st December 2017, 06:51 PM   #8
This one is really good.
Old 31st December 2017, 07:27 PM   #9
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Um, not clear if you are desinging your own. Another good alternative to the Peerless is the Faital PRO. I like the Peerless, but the Faital's tend to have better top end extension. If you wanted to do a 5" woofer or so, I'd say the Faitals are a better choice for your tweets.
OPEN BOX FaitalPRO 5FE120 5" Professional Woofer 8 Ohm
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 31st December 2017, 09:13 PM   #10
Wow. Thanks for all your great suggestions. Happy New Year too.
Yes, designing my own enclosures and crossovers.
Plenty to think about and analyse today!
Bookshelf SuggestionsHide this!Advertise here!
Driver suggestions for 4" Bookshelf rebuild Jack Sparrow Multi-Way 10 15th September 2016 01:12 PM
Looking for suggestions on a bookshelf build 1967cutlass Multi-Way 10 31st January 2016 05:19 AM
bookshelf speaker suggestions nullstring Multi-Way 13 10th September 2009 04:28 PM
small bookshelf project suggestions please gychang Full Range 4 10th November 2006 05:32 PM
Building Bookshelf Speakers - Looking for suggestions soundNERD Multi-Way 26 31st January 2005 08:10 PM
