Bookshelf Suggestions
Old 31st December 2017, 10:07 PM   #11
LineSource is offline LineSource  United States
LineSource's Avatar
Originally Posted by Roo2 View Post
I'm thinking 6.5"-7" diameter to keep the enclosure size reasonable and still give me some bass.
I have a pair of unused Vifa D25AG-35-6ohm tweeters left over from an old project.
Originally Posted by PeteMcK View Post
Local Dealers - Wagner have SB, Peerless, Vifa, Scanspeak. Best Value in Oz is probably this SBNRXC35-8 driver, $15 cheaper than the Peerless. [/url]
Should be a good marriage.
A ported cabinet of about 0.75cuft with dimensions around H17" W10" D12.5" will deliver -F3 ~42Hz. Position the port about 1" off-center for reduced baffle edge diffraction. The 3rd order Butterworth crossovers used offer even power output and enough phase shift to mask the physical offset of the tweet and mid on a flat baffle.
ALTERNATIVE: Stepped baffles which physically time align the tweeter have become popular, with the compromise of increase edge diffraction from the extra baffle board. Google and study. LR2 crossover circuits are used to phase align a stepped baffle design. Easy to design a LR2/LR2 crossover if you decide to build a stepped baffle.
Old 2nd January 2018, 12:13 AM   #12
Roo2 is offline Roo2  Australia
Thanks for that LineSource. I'm very keen to try the BW3 crossover.
I like the idea of that SB driver but it needs a bigger enclosure than I really have room for.. I realise they'll give good bass but my better half will not like the shelf getting crowded by them.. The Peerless 830875 may be good compromise. The FaitalPRO 5FE120 is also an interesting option to go smaller again. Do you think the 5" FaitalPRO will have significantly less bass than the 6.5" Peerless?
Old 2nd January 2018, 06:02 AM   #13
keilau is offline keilau  United States
Originally Posted by Lojzek View Post
This is probably the best buy at the moment.
Peerless PPB 830874 - 6.5" Poly Cone Woofer
edit: I have built one. Post #2568.
System Pictures & Description
The driver from Madisound is a wonderful deal if the shipping to UK does not kill the deal.
Lojzek, your speaker built looks beautiful. Did you publish your LR4 acoustic crossover schematic?
Old 2nd January 2018, 06:44 AM   #14
LineSource's Avatar
The SB17NRXC35-8 produces under 50Hz bass even in a 0.5cuft cabinet, which is easy to achieve with a bottom slot port or rear port.
SB17NRXC35 has a 6.7" diameter frame, and the SB15NRXC30 has a 5.9" diameter frame.
Small difference in diameter. Small cabinet size difference when both crossover and port are included.
Old 3rd January 2018, 10:54 AM   #15
Thanks Linesource. Looks like a good path.
I like the slot port concept to allow them to be placed closer to the wall.
Where can I find more info on calculating slot port dimensions?
Old 3rd January 2018, 11:36 AM   #16
Ugg10 is offline Ugg10  United Kingdom
here are a couple of slot calculators -
L slot - Enclosure Calculators Archives - DB DYNAMIX AUDIO
Simple slot - Port Length Calculator
Old 3rd January 2018, 04:22 PM   #17
LineSource's Avatar
Will the 0.6 cuft cabinet in this article meet your size and style goals?
-Loudspeakermagazine 2012 > April 2012 > SB 18
SB 18 - April 2012 - Loudspeakermagazine 2012 | Loudspeakerbuilding
If you decide to reduce the internal volume to 0.5cuft, keep the internal width = 19mm = 7.5" and modestly reduce the depth and height.
SLOT PORT for 0.5cuft internal volume. Width = 7.5" Height=0.5" Depth =9.7" (which include the thickness of the front baffle)
You can get reduced baffle diffraction if you mount the tweeter 1" off-center. This spreads the pressure wave energy over a wider variation of baffle lengths.
Mount the crossover behind the tweeter so it will not restrict woofer air flow.
Old 3rd January 2018, 10:38 PM   #18
Thanks all.
Yes, that article with 0.6cuft enclosure looks very good. Just need to find decent 21mm plywood here in Aus..
Old 5th January 2018, 09:47 AM   #19
Hello again. The SB17 drivers are ordered! I’m looking for the BB3 crossover bits now. Can anyone recommend some capacitor make/models that are good and reasonable value?
Old 6th January 2018, 02:10 PM   #20
Xerxes75 is offline Xerxes75  Netherlands
I wanted to build a two way with the SB Acoustic Satori but that did not fit the budget. So a few weeks ago I decided to build the SB18 which is more budget friendly.
I don't have the time yet, I am curious about the results!
R.
LM3886, LM4780, DCB1, DAC, First One v1.3, vintage drivers..
Bookshelf SuggestionsHide this!Advertise here!
Driver suggestions for 4" Bookshelf rebuild Jack Sparrow Multi-Way 10 15th September 2016 01:12 PM
Looking for suggestions on a bookshelf build 1967cutlass Multi-Way 10 31st January 2016 05:19 AM
bookshelf speaker suggestions nullstring Multi-Way 13 10th September 2009 04:28 PM
small bookshelf project suggestions please gychang Full Range 4 10th November 2006 05:32 PM
Building Bookshelf Speakers - Looking for suggestions soundNERD Multi-Way 26 31st January 2005 08:10 PM
