Refurbishing  JBL 4310 and 4412
Old 2nd January 2018, 03:44 PM   #11
Blaukomma is offline Blaukomma  Germany
Surrounds arrived today and i tried to get rid of the black paint and it seems it works fine. Hell lot of work but i think the 4412 will look perfect in a while.
I will post some photos this week.
Old 3rd January 2018, 05:32 PM   #12
wesayso is offline wesayso  Netherlands
wesayso's Avatar
Can't wait to see the transformation .
Use Science to design your speakers and they will sound like a piece of Art...
Old 4th January 2018, 05:35 PM   #13
Hi guys! I refoamed the 128H-1 and both are working fine again. Had a little bit of trouble with the glue syringe.. the needle popped of and the glue.. everywhere.. but at least not on the cone (as you can see).
I kept on sanding down the first 4412 and this is how it looks like:
As you can see the overall veneer is still very stained and not really smooth. The pores are filled with black paint and i`m not sure how to move on now. If i keep on sanding it will look like the corner (without black paint pores) but i`m afraid to sand through the veneer destroying it..
Don`t know if i can live with this stained appearance if i could maybe had the chance to remove it..
What do you think?
"leave it stained and with black pores!"
or
"sand it down until you get a clean and smooth paint free walnut venneer!" - with the risk of destroying it...
Best wishes from germany!
Kai
Old 27th January 2018, 10:38 AM   #14
wesayso's Avatar
What did you end up doing? Any new pictures?
Old 27th January 2018, 03:23 PM   #15
Top Shelf is offline Top Shelf  Canada
Top Shelf's Avatar
Try using a green 3M scrubby pad with paint thinner and a light touch to see if it will remove the paint spots in the pores, rubbing with the wood grain. Try a test section on the bottom of the cabinet first to see if the thinner will discolour the veneer or make it lift (by thinning the veneer glue).
I would NOT use steel wool for this as the fine steel wool particles may become airbourne and go through the port into the voicecoil.
NO REST FOR THE WOOFER! 🔊😈
Old 28th January 2018, 02:22 AM   #16
dotneck335 is offline dotneck335  United States
I can't help but wondering how much better the JBL 4310s would sound if tri-amped......??? Anybody ever try it?
Old 3rd February 2018, 02:59 PM   #17
phase is online now phase  United States
I would be tempted to try some of the toxic paint stripper and see how it works to remove the paint residue. Maybe on the underside of the cabinet?
Old 3rd February 2018, 03:30 PM   #18
phivates is offline phivates  United States
I suggest the "green" stripper rather than the old methylene chloride stuff, which dries too fast. Also the auto paint store has gray abrasive pads which are less aggressive than the green or red. Third, just stop and call it good when it isn't working and find a stain which will mask the leftovers. Sometimes the gel version works when some concealing needs to happen. Too bad Watco doesn't work for everything.
Not a fan of Minwax products. Varathane used to be better but both are on the same display at Lowe's these days so who knows?
Refurbishing  JBL 4310 and 4412Hide this!Advertise here!
JBL 4412 cab modification. Possible? honkyjonk Multi-Way 15 10th February 2017 08:37 PM
JBL 4310 KenHoard Swap Meet 0 20th November 2015 01:07 AM
mounting jbl 4412 speakers from ceiling lexx21 Multi-Way 1 1st August 2015 09:11 AM
JBL 4310 fiberglass behind mid-driver paulnparis Multi-Way 23 17th September 2011 05:07 PM
jbl 4310 - bad bass paulnparis Multi-Way 13 8th April 2009 10:18 PM
