Coaxial Speaker Build Thread with FaitalPro 6HX150
Old 13th January 2018, 08:53 PM   #51
drewan is offline drewan  United Kingdom
Hi, Thankyou thankyou thankyou on how to make a jig for awkward shapes. I'm 30 yrs a carpenter and didn't know how to do that. Any good ideas about a jig for the FE4?.
Old 19th January 2018, 06:32 AM   #52
JShadzi is offline JShadzi  United States
JShadzi's Avatar
Default Coaxial Speaker Build Thread with FaitalPro 6HX150
Hah my pleasure!
Old 19th January 2018, 06:32 AM   #53
JShadzi's Avatar
Ok coming along, wrapping up the saw dust phase of the project!
Time for some binding posts, Iím putting in binding posts for each driver as in the future I may consider going fully active on this.
Iíll be doing a recessed bowl cut for the binding posts, the recessed circular binding post provision has sort of become a little design detail on every build I do, and Iím taking it to the next level by doing a curved bowl cut. The binding posts are located between the two lower braces in the enclosure
The ID of the template is 4Ē, which is held securely with double sided tape
And the bowl cut
As you can see the bottom cut of the bit doesnít leave the smoothest surface
Template removed
Surface irregularities are easily removed with a 2 inch sanding disc
After sanding with up to a 250 grit finish
And with binding posts temporarily put in place
Since the baffle for the woofer flange was so thick I wanted to put a relief cut to make sure the woofer can breathe easily, Iím not bothering doing anything with the mid as the baffle flange is only about 1/2 inch thick there, and thereís plenty of breathing room. The challenge with the kerf baffle like this is that I really didnít want to cut driver holes before bending the kerfs as I didnít want to weaken or put any extra flex in the baffle assembly, so this meant I wasnít able to put any relief cuts from the outside so Iím doing it from the inside with this under round over bit for Magnate.
Woofer flange thickness
I lined the midrange enclosures with sorbothane, then lined that with 3/4Ē wool, then stuffed with poly fill
And ready for some crossover tuning
Thanks!
Javad
Old 21st January 2018, 05:34 AM   #54
JShadzi's Avatar
Tuning for the Pretty Persuasions is coming along well, I have initial modeling done in Xsim and I’m waiting on some crossover parts which will be here Tuesday.
In the meantime I did a quick DSP tune using a MiniDSP 4x8 Sharc, really cool unit as it runs a digital coax input which I run directly out of my laptop for a fully digital signal path into the DSP. I’m running an Adcom GFA-2535 50watt x 4 to the mids and tweeters, and an Adcom GFA-545 to the 8” woofers giving them about 100 Watts each. Crossover points are approx 1000hz at 48db and 200hz at 24db, the amount of PEQ was minimal, I used about 10 filters total to create a response w/in a dB or two full spectrum, and it could be even flatter.
Bass response is flat to about 35hz, my initial impression with this woofer and enclosure are excellent, bass is tight and fast with a warm ported sound and no bloat or sloppiness. My only concern with this woofer (I need to test the other), is that at close to xmax it does make a small sound I can hear if I’m close to it, almost sounds like tinsel slap, I need to investigate further, worst case there are several other more high end woofers with 220mm frames I can use if I need to (I just need to mind a tight budget for the InDIYana event).
See attached for response charts, active makes it so easy to hit whatever response you desire, my passive crossover won’t be nearly this smooth. I also took a few videos, these won’t be winning any Golden Globe awards but they show the speakers, give you an idea that they don’t sound terrible, check them out.
Overall I’m thrilled with how this one speaker sounds in mono, if I have time tomorrow I’m going to assemble the second speaker and listen in stereo, that should be a treat. This is definitely a point source speaker and it sounds like it, I’ll write more about the sound as I spend more time with these guys. Thanks!
Response on axis no smoothing and 1/6, this is with the mic 20” from the tweeter
With individual driver responses
On axis, 22d and 45d
Video of one speaker playing in mono, also showing some of the DSP setup
[video] YouTube[/video]
Old 21st January 2018, 05:35 AM   #55
Pallas is offline Pallas  Pakistan
Why mar an interesting speaker design with primitive kludge connectors when the Speakon exists? In 4- and 8- pole variants?
Serious Audio Blog
Old 21st January 2018, 06:23 AM   #56
JShadzi's Avatar
I guess I prefer ďkludgeĒ connectors like most speaker builders, they allow flexible connections for just about any speaker wire option. After everything Iíve posted this is the one comment you have though? *rolls eyes*
Thanks,
Javad
Old 21st January 2018, 02:48 PM   #57
phivates is offline phivates  United States
+ 2 eyes rolling
Old 21st January 2018, 10:51 PM   #58
Pano is offline Pano  United States
Pano's Avatar
Here's my "one comment". That router bit is boss! Haven't ever used one like that.
Old 21st January 2018, 11:33 PM   #59
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Looking very sexy.
Old 21st January 2018, 11:58 PM   #60
mordikai is offline mordikai  United States
Send a message via Yahoo to mordikai
Keep it up Javad, looking good!
Coaxial Speaker Build Thread with FaitalPro 6HX150Hide this!Advertise here!
The umpteenth large format coaxial driver thread Adolf Corkscrew Multi-Way 198 13th February 2018 11:32 PM
first budget MTM garage speaker build thread kcducttaper Multi-Way 15 11th October 2017 02:25 AM
Strafi Translam FaitalPro Tower Build JShadzi Multi-Way 164 22nd August 2017 02:56 PM
Tony Gee's Low Budget Speaker - Build Thread mrevie Multi-Way 27 18th April 2011 11:40 PM
Feasable to build a DIY coaxial? sprinter Multi-Way 2 24th February 2011 04:02 AM
