Old 5th April 2004, 03:40 PM   #1
Default Driver Selection help. Please!
Hello All,
I am looking to build a pair of Floorstanding speakers.
I am looking to use Accuton drivers. So anyone with experience with these drivers please help.
My question is:
What would you do?
2 way using their 7 inch and 1 inch tweeter?
or
3 way using their 7 inch, 3.5 or 5 inch (the model with the Ears) and a 1 inch tweeter.
Any feedback would be appreciated.
oh. I have an electrocompaniet amp with plenty of power. I am not concerned too much with physical size, and I listen to Jazz, R&B, Rock ...
Old 5th April 2004, 08:31 PM   #2
coolkhoa's Avatar
Send a message via AIM to coolkhoa Send a message via MSN to coolkhoa Send a message via Yahoo to coolkhoa
I have no experience with Accuton drivers whatsoever, but the LDSG may be helpful.
KTK. Kool To the Kore.
Old 6th April 2004, 02:55 AM   #3
Anyone have any firsthand experience with Accuton?
Old 6th April 2004, 06:33 AM   #4
Kekkonen's Avatar
It´s better to build good 2-way than semi-good 3-way.
there are more broblems to fit 3 than 2 elements together.
Loud and Clear said my Granny.
Old 6th April 2004, 10:46 PM   #5
TTT
Old 7th April 2004, 01:29 AM   #6
Rocky is offline Rocky  Norway
Rocky's Avatar
jainbaby,
The 7 inch accutons goes high, and will make great companions for a C23 in a 2.5 way system, but do not provide much deep bass. 2 of them however might give sufficient (for some) bass response, but keep in mind one of them will still also have to take proper care of the important midrange area.
If you intend on going 3-way, wich will be beneficial because the woofer will not have to take care of the important vocal area from 200-2000Hz, I would recommend to use another woofer than the 7'' Accuton, as there are far better bass drivers around.
Eton 8'' or larger makes a great match for a system using the C79 midrange and C12/C13 tweeter, XO at approx. 300Hz and 3000Hz. Killer combo!
if 7'' are your choice to keep the baffle narrow, why not check out the ScanSpeak carbon woofers? their 7'' inch 8385 goes very deep.. It is really something special.
Old 7th April 2004, 01:39 AM   #7
Rocky's Avatar
Default Re: Driver Selection help. Please!
or
If you go for a 2.5 way, you need a tweeter that can be crossed lower than accutons 1 inch. The 1.2" is a must, I would say.
But if you can handle the complexity of a 3-way, the suggested Eton woofer/Accuton 3.5'' mid/Accuton 1'' tweeter combo will give much more sound for almost the same ammount of money. Both in deep bass, high midrange, and superheights (as the 1'' goes higher than the 1.2'')
Rocky
Old 7th April 2004, 03:37 AM   #8
Rocky,
Thanks for the input. I am not stuck on the Accuton 7 inch.
I just would like to use Accuton mid and tweet.
So your recomondation would be the 3.5, 1 or 1.2 and an Eton woofer.
I was thinking a Focal Utopia woofer, what is your opinion?
Old 7th April 2004, 04:24 AM   #9
I agree with Rocky totally.
"I am not concerned too much with physical size"
If that's the case then go for a large (bigger that 10") woofer like an Eton, Focal, or an A.T.-FLEX Unit
It's better to have loved & lost than to never have had a good pair of speakers at all.......
Old 7th April 2004, 04:25 AM   #10
An example:
driver selection help dallaire Multi-Way 4 2nd December 2007 08:02 AM
Need Help with Driver selection Jlace Car Audio 2 24th March 2007 07:26 AM
driver selection help SamClassA Multi-Way 11 31st August 2006 12:16 AM
3-way driver selection boostin1989 Multi-Way 2 6th June 2006 06:58 PM
2-way driver selection. jazzbearz Multi-Way 5 6th February 2005 05:25 PM
Page generated in 0.10739 seconds (78.13% PHP - 21.87% MySQL) with 11 queries
