I will take a look, its likely the cabinet will need to change.
The crossover will definately need to change. This DS-215 does look like a good option from the Dayton range.
Hi Andrew, when you simulated the drivers did you get the DS-215 data ?? I read you mentioning an aluminum cone woofer and I am confused. There is one DS-215 and one DA-215. I want to be sure you did it with the DS-215. The DS-215 isn't an aluminum cone woofer. Thank for all your help.
Dayton Audio DS215-8 8" Designer Series Woofer Speaker
Dayton Audio DA215-8 8" Aluminum Cone Woofer
Kind of interesting Troels never had any tall slim designs (actually he might have had one but the design was probably not very optimal). I keep telling him that he needs to improve the look of his designs.
I am almost certain it was the DS215 data I captured (I must have got confused over which driver was the aluminium one). However I am away from home with work in Romania at the moment and all the CAD files are on my home PC. I will be back on Friday and can make sure then. Also I think I sent you the screen grabs I used to input the data so you check on those and compare with the data sheets to see which one I inputted.
He does look for the tall-slim floorstanders.
Hi, I just checked the original downloaded Zip file from the Dayton site and it is definitely the DS-215 that I used the data for sorry for any confusion my referencing aluminium drivers cause.
Andrew
Andrew
Andrew
Thank you.!
