SNR-1 : Mundorf / Scanspeak 2 Way
Old 3rd January 2018, 05:23 AM   #51
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Steve,
I'm sincerely speechless.
Erik
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 3rd January 2018, 08:40 AM   #52
ODougbo is offline ODougbo  United States
lol Did you see these? PE stocks them:
btw, Super easy to make Test Baffles for experiments , basically glue two 1/2" mdf boards together (or other wood). The outside edge would need to be rolled over with a router, but not the deep rabbit cutting.
[Or just buy extra blanks]
Old 3rd January 2018, 11:50 AM   #53
Zvu is offline Zvu  Serbia
Zvu's Avatar
Originally Posted by eriksquires View Post
I should point out that I added near field measurements to the XSim I posted here, so below 500 Hz or so you'll notice a difference. I spliced in the port contributions, but I am really not sure I did that right. I will say I was guided by in room response in splicing, not math, so, could definitely have messed it up.
Splicing is always aproximation. I do it at an end of a project to see quasi anechoic measurements aproximation. What works for me is nearfield measurement of midwoofer (under 2cm distance) and gated farfield measurement of whole loudspeaker (gating at least at 300Hz or lower). Then i merge it between 300-400Hz. Sometimes i do groundplane measurement and merge it to gated farfield - it shows more consistent results because i don't need to measure port output and merge it to nearfield.
Anyway, good gate goes a long way. Point of my post is to get precise quasi anechoic measurements at least on axis to see if your measurements will match with Troelses. Whatever i may think of Troels designs, his measurements are spot on in my experience and it would worry me if my measurements wouldn't match his.
Not claiming that your measurements are faulty, but certainly something to be investigated.
Not for fainthearted
Old 3rd January 2018, 01:17 PM   #54
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
I have nothing against measurement, absolutely.
But for me, "well-measured" speakers never sounds good for my ears.
For example, Troels measurements always have pronounced bass.
The upper middle are weak expressive; high - almost no.
Bad for me
First, I'm not a "bass man". For me, good sounding 50Hz is more than enough.
And I need a little more pronounced upper frequency.
Everyone has their own taste
But I'm 64 and that's for me.
Old 3rd January 2018, 01:37 PM   #55
Zvu's Avatar
You can open a thread about that in which i'll be happy to participate.
In short, my experience is quite different than yours. Speakers that measures well, sound well.
I never said that Troels speakers measures well or bad (i can only say that for a particular design - i could never generalize). I said that his measurements are accurate.
Old 3rd January 2018, 01:44 PM   #56
RajkoM's Avatar
Ok Zvule,
Threads where very subjective opinions are expressed are useless and usually ends ugly.
But if we ever meets, ones .....
Najbolje želje i sretna Nova godina.
Erik, sorry for OT, please
Old 3rd January 2018, 02:50 PM   #57
I should also point out, I have another schematic from Madisound with the same woofer. The woofer measurements are very very close to my own. So, I'm fairly confident that the raw woofer driver, especially around the crossover, is accurate. Plus, I'd hear an exaggerated midrange hump.
It's just not as bad as the specs say.
Best,
E
SNR-1 : Mundorf / Scanspeak 2 WayHide this!Advertise here!
FS : Jantzen coils, Mundorf Coils, Mundorf ECaps gdan Swap Meet 4 21st November 2017 03:52 PM
Scanspeak D3004/660000 5 x scanspeak 2608/913000 oldbar Swap Meet 0 23rd September 2015 08:51 AM
Mundorf Supreme, EVO, Audyn, jantzen, russian caps, Mundorf Resist, XHadow, KLEI rca edbk Swap Meet 20 24th June 2015 12:37 PM
WTB: Scanspeak D2905/9900 scanspeak murphythecat8 Swap Meet 0 24th October 2011 07:02 PM
Mundorf Components..... ermes Multi-Way 6 26th June 2004 02:18 PM
