Try a google image search for "tweeter waveguide" and you should see some reasonable substitutes. These would require just a parts swap:
monacor wg-300 wave guide
Home page DIY Sound Group (Seos 8)
or a twofer: the Dayton Audio ND25FW-4
The Monacor looks like a very close match. The others may need minor crossover tweaks.
Note that the waveguide Zaph used was a hack: he cut the throat off a screw-on horn. This one looks exactly like the MCM, and could similarly be hacked.
http://www.altronics.com.au/p/c6127-round-compression-driver-flare-suits-c6110-c6115/
If it makes any difference, I could acquire a couple and send them over (they are in stock ~locally).
Thank you. I appreciate the info!
