Onkens - Benefits? Design Considerations?
Old 6th December 2017, 05:39 PM   #11
kevinkr's Avatar
The Onken design is based on the old Jensen Ultraflex.
I built a pair of Onken bass boxes more than a decade ago, they are the only part of the system that has not been replaced in that time.
I continue to be happy with their performance but have made some changes since built. (basically just the materials used for internal damping which are surprisingly critical - lambs wool or wool based carpet underlayment work better than more modern materials)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 6th December 2017, 09:59 PM   #12
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Sort of. As I understand it:
-Thuras invented & patented the bass reflex (which is different to Novak, and latterly Thiele, then Small's, vented box) in 1934. Jensen created the Ultraflex variation on the theme a couple of decades later. These boxes use their huge (by typical current standards) vent systems to target maximum acoustic efficiency at Fb.
-Post Novak, Thiele, and some of Small's work, the Onken is created. It is a specific variation on the 'modern' vented box theme, hybridising the massive vent structure of classic reflex design (and exploiting the convinient Ultraflex layout) with the ducted vent & specific filter based alignments using Q, Fs and Vas to determine box volume and Fb. As a result, Onkens share some characteristics with classic BR design (lots of vent area) with regular vented boxes. Because of the massive vent area, the ducts are, in general, relatively long, and as a result their 1/2 wave resonant modes tends to create midband colouration.
-Dave Dlugos's enclosures physically resemble Onkens & the Ultraflex but are functionally different, as he deliberately uses a high vent aspect ratio & the resistance / friction generated to push the box alignment toward / into a quasi-aperiodic function. This is significantly different to the Onken, where tuning is basically similar (albeit with vent harmonic resonance & with particular tuning goals) to a conventional T/S vented box, and almost the polar opposite to the classic BR & the Ultraflex.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 6th December 2017, 10:15 PM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by GM View Post
It was in this French article among others
Here is Hiraga’s article, Google translated into English and pdfed.
http://www.planet10-hifi.com/downloa...ns-english.pdf
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th December 2017, 10:36 PM   #14
Henderson is offline Henderson
Banned
I used to hear an Onken W ! You need the room for this serious punchy bass... Need also drives with Fs lower than 30 Hz (Altecs were around 25/30 Hz, much harder to find today ! Think the big Tannoys get the both of the two worlds :energy and plexus upercut in the upper bass from the Vott and lows extension of the Onken... and clean low mid : Onkens are not only subs but a very good low mid made for XO around 700 Hz and horn above)
Iir: onken were liked in Japan because havin the low-end lacked in the Vott... !
BR you see today in the Stereophile class A are poor toys for kids vs a serious Onken W, imho !
Old 6th December 2017, 10:37 PM   #15
soendervig is offline soendervig  Switzerland
Default Erh , regarding that translation ...
You just got to love french . Last sentence of the translation . While "enceinte" indeed does mean pregnant , and therefore is translated quite correctly , whenever the same term is used around audio , it ought to be translated with "enclosure" . Try figure...
Cheers
Kim
Old 6th December 2017, 10:41 PM   #16
Default PS.
Just saw that it was a google translation . Explains a lot ; expecting them to know the difference is probably asking too much....
Cheers
Kim
Old 6th December 2017, 11:07 PM   #17
frugal-phile(tm)
planet10's Avatar
If i had software to edit text in a pdf (i might be able to import it into something and then re-eport it) i’d have the inclination to go in and clean it up a bit.
dave
Old 6th December 2017, 11:13 PM   #18
Banned
craftsmanship : Réalisation du caisson Onken 360 litres (P.Viboud)
Old 6th December 2017, 11:13 PM   #19
Yes , but then it's nice with a chuckle once in a while
Come to think of it , perhaps it was the old B+W DM 6 that caused the french confusion in the first place.....
Good night ,
cheers
Kim
Old 6th December 2017, 11:42 PM   #20
frugal-phile(tm)
planet10's Avatar
Originally Posted by Henderson View Post
craftsmanship
You want to see craftmenship you should see some of Bernie’s solid wood miniOnkens (a reminder, as i stated, and Scott emphasized, not an Onken). truly artpieces and some while not as large as in the article you posted, still big — monster miniOnken (this is not near the biggest built to date — those are some 3+ x the volume).
dave
Onkens - Benefits? Design Considerations?Hide this!Advertise here!
New Design-HEXFET Poweramp. Sonic benefits of this approach. Mooly Solid State 85 7th June 2014 06:23 PM
Bandpass design considerations loddie Subwoofers 16 10th December 2009 01:06 AM
