Measurement files for Scan 15W/4524T02
Old 5th December 2017, 06:14 PM   #1
Fernando R is offline Fernando R  United States
Default Measurement files for Scan 15W/4524T02
Does anyone have measurement frd and zma files for Scan Speak Discovery 15W/4524T02 drivers? CLIO .txt files will also help.
He uses numbers and statistics like a drunk uses a lamp post; for support rather than illumination.
Old 7th December 2017, 08:33 AM   #2
giralfino is offline giralfino  Italy
giralfino's Avatar
Measurement from other people are useless unless you build the same enclosure and baffle. Best to trace yourself the infinite wall measure provided by the manufacturer (5 minutes work with spltrace or equivalent tool).
Ralf
Old 7th December 2017, 03:12 PM   #3
I am completely aware of the limitations. However, they are not useless. They can give you an idea whether or not if the driver will model well within your application and if it is worth buying.
Old 7th December 2017, 04:29 PM   #4
giralfino's Avatar
With a reputable manufacturer like Scan Speak I frankly prefer to trust them instead of someone else. Published T/S parameters will give you an idea of what can be obtained with different bass alignments. Published FR, once traced with an appropriate tool like spltrace, can be manipulated with other free tools like response modeler in order to simulate baffle effects. This is all you need in order to decide if a driver is worth buying, if you omit distortion information (that a frd won’t give you however).
Ralf
Measurement files for Scan 15W/4524T02Hide this!Advertise here!
Getting PCBs printed from DXF files (or Ultiboard files) MitchMev Software Tools 6 28th June 2016 09:45 PM
Desperately seeking measurement files... frangus Multi-Way 5 6th December 2013 07:19 AM
Devin's Aethers - measurement files attached critofur Multi-Way 1 18th October 2008 11:33 AM
i'm searching scan-speak tw measurement files. ermes Multi-Way 0 5th April 2005 07:43 AM
PL27TG35 & HDS 164 (phase plug) Measurement files Leffemannen Multi-Way 0 30th December 2004 09:26 PM
