In some passive X-overs there are resistors in parallel with some of the L&C components. I think I've seen them described as being there to prevent "ringing". What do they do? Is there a way for the DIYer to determine when they are required and how do you calculate appropriate values? Jonathan bright
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. |
#2 |
Possbly, the designer has at some stage seen a bump or a dip or something in the frequency response, and figured out that it can be fixed by adding that extra L, R or C. Crossover design i built on basic theory (dBs per octave, butterworth/linkwitz, baffle step compensation etc) but is also a commonly used to fine-tune the frequency response. I suppose that this is what you have seen. It is hard to give general recommendations regrding those extra components, the best way of understanding them is to understand passive electric circuit design.
IMO any explanation that uses time-domain wordings, like "step response" and "ringing" should be viewed with the sceptic eye. I'm not saying they are wrong, but most often they don't help much but rather cause confusion and/or wrong conclusions. This does not apply only to crossovers. |
#3 | |
They are often included for subtle adjusts to phase and
levels in the crossover region to help with subtle driver integration issues. They are not needed to prevent ringing or facilitate a decent step response, this is mainly controlled by the Q and order of the crossover alignment. Quote:
software, and enough skill to only use extra resistors when they are definetely needed. |
#4 |
diyAudio Retiree
"Damping"resistors in X-overs. What do they do?"
I'll be damped if I know........... |
#5 |
Actually, "ringing" is also a not-uncommon term to describe the oscillation that can occur in LC circuits, particularly in high-order crossovers comprising multiple inductors and capacitors. And a well-placed resistor could certainly be used to shift a troublesome resonant frequency out of band, or otherwise tame a problematic oscillation.
I believe this issue is also one reason why people sometimes substitute multiple small capacitors for a single large one. Of course it's difficult to tell if that's what the designer intended without an actual example, but theory certainly supports this as a reasonable explanation. |
#6 | |
The Q (i.e. ringing and step response) of higher order LC circuits can be completely controlled by correct component values. Multiple capacitors will not reduce Q, due to lower losses if anything Q will increase. There is one case where damping resistors are required : If you want a response between first and second order. |
#7 | ||
#8 | |
Q 2nd order is the more sensible way to approach this. http://www.users.nac.net/markowitzgd...tcrossover.htm http://www.users.nac.net/markowitzgd/david/watt-x-o.gif The CB17RC c/o is basically 2nd order but asymptotes to first order at high frequencies, why ? who knows ? But Thorsten is simply copying the original c/o. |
#9 | |
#10 |
Really should also note that for bass / midrange units any
resistor of in the area of 3R to 8R in parallel with a series inductor is for Baffle Step correction. And in crossovers resistors can be used for correcting the overall response of the driver, and of course be used for setting the level of the midrange and / or tweeter. |
| Do we really need high priced "audio grade" power resistors? | panson_hk | Parts | 2 | 23rd April 2009 11:11 AM |
| Building "Munny" Speakers, need advice on damping material, grill cloth... | paulmurphy | Parts | 1 | 8th August 2008 06:10 AM |
| Omitting "emitter" resistors in power stage | Baldin | Solid State | 8 | 27th December 2007 10:26 AM |
| a nice application note about damping LC networks "snubbers" | mirlo | Power Supplies | 7 | 11th November 2005 09:46 PM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.12241 seconds (84.73% PHP - 15.27% MySQL) with 11 queries |
