How to Make a New Wave Biradial Horn
Old 6th December 2017, 07:57 PM   #51
Chris Koerbel is offline Chris Koerbel  Germany
Default Cool thread
What Could Be a „modern“ Alternative to a 2425/26 on a 2344A?
Any Suggestion?
Any experience?
(Tad 2001 is wayyyyyy over Budget, no Alternative)
Chris
Old 6th December 2017, 08:44 PM   #52
EarlK is offline EarlK  Canada
Any Suggestion?
Any experience?
Chris
PH-230 from Bluearan
How to Make a New Wave Biradial Horn-8hub2qn-png
Old 6th December 2017, 09:13 PM   #53
gedlee is offline gedlee  United States
gedlee's Avatar
Decades of research have shown that sharp edges on horns create diffraction and should be avoided. This means no diffraction slot, or sharp edge terminations. The sonic effects of doing this are quite impressive. There is a lot of information on this topic here at DIY. See "Geddes on Waveguides" for example.
Earl Geddes Gedlee Website
Old 7th December 2017, 08:45 AM   #54
Sorry for misleading you and thanks for your answer.
The question was more in regards of replacing the 2425/26H with something more "actual" on a given 2344A horn.
Anybody ever tried out BMS 4550?
Answers are appreciated from this perspective, again
Chris
Old 7th December 2017, 01:08 PM   #55
marco_gea is offline marco_gea  Italy
There is no point in doing so. The 2344A horn is the weak link, not the 2425/26 driver.
Marco
Old 7th December 2017, 02:35 PM   #56
As Marco said, it's the 2344 that's the problem ( as far as having linear response goes ) / though the ( BMS ) 4550 does fare better in its mid-band response ( as far as diffractive suck-outs go ).
Here's an ancient trace ( from Zilch ) that shows what a challenge the 4550/2344 combo would be ( to design for ) .
Of course, one can actively EQ almost anything flat / but creating a workable passive network to fix what's seen in the red trace below would test the best network designer.
How to Make a New Wave Biradial Horn-zilch_bms-455x_on_2344-jpg
The following Celestion driver doesn't fare much better ( IMO ).
How to Make a New Wave Biradial Horn-cdx1747_on_2344_fr-png
Mind-you, I suppose those ( above ) are still better ( 1-5K wise ) than the raw response of this 2425 on the 2344.
How to Make a New Wave Biradial Horn-response2426on2344_d16r2421_d8r2425-jpeg
With the compensation filter in place, response will eventually look like this;
How to Make a New Wave Biradial Horn-2425-2344_widget_3135_-jpg
The above trace ( intriguing to me at least ) is flat enough to support the love-in going on ( over at AudioKarma ) over the 4435 speaker.
Some new 4435 devotees are really driving quite a renaissance over its capabilities.
The TAD 2001 is not immune to the negative effects ( on FR ) of this horns builtin diffraction problems.
How to Make a New Wave Biradial Horn-tad-vs-jbl_response-jpg
File Type: jpeg Response2426on2344_D16R2421_D8R2425.jpeg (55.5 KB, 214 views)
Old 7th December 2017, 03:06 PM   #57
wow, Earl - impressive investigation
Thanks for the moment, I need to study more deeply
Chris
PS: so bottom line: you would recommend to use a different horn and a different driver... 4435/30 is not a great speaker respectively can be done better?
Old 7th December 2017, 03:42 PM   #58
phase_accurate is offline phase_accurate
I would say it differently: They are still great speakers but we have better possibilities nowadays.
Charles
Old 7th December 2017, 03:52 PM   #59
Chris
This is a good waveguide ( previously mentioned by Patrick ) .
How to Make a New Wave Biradial Horn-qsc_152i_15nngyr-png
PRV made a clone for a while.
Both ( the QSC 152i & the PRV clone ) are NLA unfortunately .
I'd seriously consider this w-guide driven by a JBL 2425/6/7h.
Response seen below ( 1/2 meter testing distance ).
How to Make a New Wave Biradial Horn-jbl-2427h-prv152i-clone-png
This is a well behaved ( raw ) response and is easily compensated for ( within a passive crossover ).
Unfortunately, these wave guides are no longer sold .
Maybe Patricks version will work out for you.
PS; the SEOS 18 would be worth a look at ( they are available over there in Europe ).
Old 7th December 2017, 04:52 PM   #60
The PT waveguides seem to perform nicely as well:
JBL D2430K mounting issues
So does the Eighteensound XT1086 (although it won'z go down to 1 kHz):
2-Way DiY Hifi speakers eighteensound
Charles
How to Make a New Wave Biradial HornHide this!Advertise here!
Horn Extender/Wave-guide for TH weltersys Subwoofers 157 19th July 2017 10:24 AM
Ok, I get it. A wave guide is not a horn. peteleoni Multi-Way 17 8th September 2013 07:22 PM
12" full range on a backloaded horn, BIB, tappered quarter wave or other horn boxes? c3conv Full Range 1 27th July 2011 06:37 PM
biradial or exponential holger honda Multi-Way 0 15th June 2005 04:25 PM
how to make a clean square wave? sss Solid State 23 6th September 2004 11:55 PM
