How to Make a New Wave Biradial Horn
Old 12th February 2018, 06:39 PM   #171
silverprout is offline silverprout  France
silverprout's Avatar
Originally Posted by Ro808 View Post
I have these as well.
I've bought some specific MDF (resin doped) with diferents colors in order to make great modular orientable enclosures.
Sherefore, Silverprout is working hard on the cabinets
Things I Should Have Learned In School (But Probably Didn't)
Old 12th February 2018, 06:41 PM   #172
Ro808 is offline Ro808  Netherlands
The response graph I posted a few pages back is from a Sica 15"
You may consider this woofer, beautifully made (in Italy) with only a few parts from China:
and this Compression driver (the Poly version, though the Titanium version is cheaper and also very good):
Very high value for money, but compare prices between different shops, because they tend to vary.
Old 12th February 2018, 06:58 PM   #173
Last week, I bought these 2nd hand, but new and unused in the box for 75:
File Type: jpg Sica LP 385.75-1800 WT 8 ? (Z008291)_MP_3.JPG (71.4 KB, 225 views)
File Type: jpg Sica LP 385.75-1800 WT 8 ? (Z008291)_MP_5.JPG (76.7 KB, 220 views)
Old 12th February 2018, 07:01 PM   #174
Don't forget to post some pics!
Old 12th February 2018, 08:04 PM   #175
I can't because it is not a radial horn !
Italy :
Sica
Faital pro
B&C
18 sound
RCF
Ciare
in tutto il mondo
Old 12th February 2018, 08:46 PM   #176
Yes you can!
The throat is quite smooth, similar to the QSC/PRV waveguide:
Response with the comp. driver from above:
Actually, the Italian manufacturers are:
- Faital Pro
- Sica (Jensen)
- B&C = owner of 18Sound = owner of Ciare
- RCF.
All high quality brands.
The other brand that I would immediately add to that list, as far as quality is concerned, is from Spain: Beyma.
Old 13th February 2018, 08:13 AM   #177
I've forgot jensen
Excuse me but, this is not a WG, it's a real horn
Old 14th February 2018, 01:42 AM   #178
By definition of Dr. Geddes:
"With the “waveguide” approach, one can find that precise contour that allows the wavefront to progress to the shape that is required at the mouth to achieve the desired directivity. This is done with minimal diffraction and the resulting sound quality is distinctly improved. To me this is a waveguide – when there is a minimum of diffraction used to achieve the end result of directivity control. This can only be done through complex analysis and clearly, not every horn is a waveguide under this definition.
These days it is possible to use FEA or a large number of other techniques on devices that have varying cross sections to calculate their directivity. Doesn’t this then make them waveguides? That’s actually a good question, but has been shown to be somewhat academic."
It's deeper and its initial expansion rate at the throat is lower compared to many known waveguides, which isn't necessarily a bad thing. I skipped the SEOS for this reason. Does this make it a typical horn? I don't think so.
The polars aren't too bad and it definately doesn't sound like a typical (diffraction) horn. I think I'll customize mine somewhat by adding roundovers at the mouth. Might even make a mold from the innards with added roundovers and "press" a horntop in liquid wood.
Old 14th February 2018, 07:09 AM   #179
The horn that i've choosen is a very simple asymetric exponential profile with a discontinuity in the begining of the throat.
Therfore the directivity is constant and the acoustic energy is concentrated on a narrower lobe, wich mean that the efficiency is higher.
Old 14th February 2018, 01:40 PM   #180
Yep, I was able to overlay an exponential curve and draw a line from the center of the throat tangent to the walls, which would disqualify it as a waveguide and make it a real...
How to Make a New Wave Biradial HornHide this!Advertise here!
Horn Extender/Wave-guide for TH weltersys Subwoofers 166 15th March 2018 01:11 PM
Ok, I get it. A wave guide is not a horn. peteleoni Multi-Way 17 8th September 2013 06:22 PM
12" full range on a backloaded horn, BIB, tappered quarter wave or other horn boxes? c3conv Full Range 1 27th July 2011 05:37 PM
biradial or exponential holger honda Multi-Way 0 15th June 2005 03:25 PM
how to make a clean square wave? sss Solid State 23 6th September 2004 10:55 PM
