Hi guys. I've been doing some tweeter testing-if you're interested the results are here.
Mark K's speaker pages Hope you find it helpful. Mark K PS I had to lie about searching... |
#2 |
Looking forward to the new tests.
#3 |
#4 |
Why will you test OWII over the OWI?
Any plans to do some Thiel/Accuton og good ribbon stuff? SS9700 should be a killer, but beware of nasty breakup at 20kHz+. Apart from that, it's just great. Cannot compare to Hiquphon or Thiel in dispersion though.. None of the SS can.. |
#5 |
Good stuff! A rare combination of clear explanations and data in one place. Thanks!
#6 | |
pinkmouse/ looks for the keys for the gun locker...
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#7 |
Rocky,
I actually have a set of ow1's-but they're not that convenient to get to. Based on the ow2 measurement, I can almost guess how the ow1 will look-same dispersion, same nonlinear distortion, and likely slightly better linear distortion. I have a set of C44's, but no accuton tweeters. Unless I come across a set, I don't think I'll be testing any in the near term. The c44's will come as part of a mid test later. A ribbon test is coming in the next month or so. The problem with the ribbons is I have to make a baffle for each one. ribbons-I've got AC g2si, R1(1rst generation) philips rt8p, BG?8(I can't recall-it's a loaner) |
#8 |
Mark,
See that the Vifa xt19 performs very well, but how about soundwise ? I am just about to order one ... Zozo |
#9 |
Hi Zozo,
Well, I haven't put anything together with the xt19 yet, so I don't have an answer. I've heard a number of xt25 systems, and did think they sounded good, though I did notice ? the directivity. Mark |
#10 |
I have the option to choose between the standard XT19TD00 with no ferrofluid and the double magneted XT19BD01 variant with ferrofluid.
I know that you haven't tested the second one, but from your past experience which one would you take ? Some people are saying that ferrofluid kills microdetail. The price is almost the same, btw. Zozo |
| Tape Tests | percy | Analogue Source | 15 | 17th August 2008 10:23 PM |
| X-BOSOZ first tests | wuffwaff | Pass Labs | 116 | 16th January 2006 04:00 PM |
| First tests with my 5ch GC | Mika | Chip Amps | 39 | 24th November 2003 01:05 PM |
| Listening tests | Rob M | Everything Else | 37 | 4th February 2003 04:37 PM |
| No parameter in Klang and Ton tests | capslock | Multi-Way | 7 | 18th September 2002 06:44 AM |
| Page generated in 0.09456 seconds (78.65% PHP - 21.35% MySQL) with 10 queries |
