Old 3rd April 2004, 10:51 PM   #1
bkfix is offline bkfix  Canada
Send a message via ICQ to bkfix Send a message via MSN to bkfix
Default Sansui SP-L800 which woofers
dual 12's with tweeter 2 way
bi amp supported
i aquired these for 10 bucks canadian,
the rubber surround on the woofers is trashed.
would i be better off to replace all 4 woofers with new ones
16 ohm? as per stock or go 4 ohm in series?
should i use 2 types of woofers in each speaker for better response and bass. or all 4 the same.
planning on using my bk pro-600 amp for these suckers.
the sansui sp-l800's are rated 300w per side.
same as my cerwin vega's but much larger.
so much equipment to fix and modd. so little time. any help would be appreciated
Old 4th April 2004, 12:07 PM   #2
suggest you consider replacing the surrounds,
will be a lot cheaper and the speaker will be original.
sreten.
Old 10th April 2005, 07:29 AM   #3
Default reconed all 4
had all 4 reconed and 1 needed the magnet realigned?
this cost me $420 CAD and i couldnt be happier.
man these speakers are true monsters and mostly solid teak i believe. i've been powering them with a hafler dh-500 for now.
FS : Sansui AU-317 Bee C. Swap Meet 1 2nd April 2009 01:08 PM
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 09:57 PM
Teac AG-L800 pics (Tripath TA2022) samvel65 Class D 3 7th June 2007 07:16 PM
FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers cm7 Swap Meet 0 1st August 2003 01:59 PM
Using DVC woofers as 2 seperate woofers Hybrid fourdoor Multi-Way 2 15th June 2003 12:10 AM
Page generated in 0.07073 seconds (70.14% PHP - 29.86% MySQL) with 10 queries
