New crossover for my current speakers
Old 29th November 2017, 10:24 AM   #41
EarlK is offline EarlK  Canada
Niklas,
Hold off on ordering anything for at least a day .
Old 29th November 2017, 10:52 AM   #42
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Originally Posted by EarlK View Post
Niklas,
No problems, I'll wait till Friday
My audio and DIY blog: http://phimusic.blogspot.se/
Old 30th November 2017, 11:02 PM   #43
Originally Posted by Rullknufs View Post
Okay, in that case I'll stick to the cheaper Mundorf E-Cap Plain and save some money.
So, 15uF, 22uF, 2x1R, 2x1.5R. Is there anything else I should add?
Hi Niklas,
Whenever you want, please order:
2x 15uF BiPolar caps, 2x 1R 5watt resistors, 2x 1.5R 5watt resistors
PS; no 22uF caps
Old 1st December 2017, 05:18 AM   #44
Rullknufs's Avatar
Hi Niklas,
PS; no 22uF caps
Done!
Also, I found a cheaper website and managed to get total cost down from 200SEK to 80SEK, including shipping. Sure, no Mundorf components but I'm sure they'll be good enough for these measurements.
Old 7th December 2017, 10:00 AM   #45
Rullknufs's Avatar
I got the parts a couple of days ago but haven't had time to do any measurements. I'm also trying to figure out how to connect everything in a practical way. I can't jam three sets of cables into my amplifier. I need to make some sort of hub or something.
Also, for the measurements, should I use one of the 15uF caps or should I use both in parallell?
Old 7th December 2017, 10:39 AM   #46
AllenB is offline AllenB  Australia
You could try screw terminals.
Old 7th December 2017, 02:14 PM   #47
Parallel the (2) 15uF caps together.
Also, unless your test amp is stable into 2ohms , add a single 1.5R resistor inline to the whole load so it's around 4 ohms
- ( you could simply connect this resistor off the red terminal of your test amp if it's easier for making connections ).
Electrical supply wire-nuts can be used for wire-combining .
Old 9th December 2017, 08:24 AM   #48
Rullknufs's Avatar
Alright. I don't think my amp (Harman Kardon HK3490) will be too happy about a 2ohm load so I'll use a resistor. I got some wire nuts yesterday. Never used them before and I have no idea how they work and I don't think I'll be able to fit a bunch of 2.5mm^2 cables in there, but luckily I found some 0.5mm^2 cable that should be long enough for what I need for this project.
Old 9th December 2017, 12:02 PM   #49
Rullknufs's Avatar
It was difficult setting up the microphone but I think I managed to get the difference in distance between the mic and the woofers to within around 5-10mm. Is that good enough or should I try harder? For the tweeter measurement I set it to 500-20.000Hz but for the rest I set it at 20-20.000Hz. Eight sweeps at 1M length.
I can't upload the .mdat file here since it's too big. The .mdat file is 8.7MB and if I zip it I can get it down to 5.31MB but that's still too big for being uploaded here.
Old 9th December 2017, 12:25 PM   #50
Hi Niklas,
You'll need to redo those measurements ( I believe you moved the mic if I read your words correctly ) .
Oh, REW doesn't handle multiple sweeps well >> so just do a single sweep of each position.
Make sure the mic is centered on the tweeter axis ( horizontal & vertical ) then ( in order ) ;
(i) Make a fullrange measurement at 1 Meter
(ii) Then make a tweeter only measurement ( 100hz & up ) without moving the mic
(iii) Then make a 2x woofers measurement ( fullrange ) without moving the mic from the "on-tweeter" axis.
(iv) OK, this is new.
- Make a single woofer measurement on axis ( vertical & horizontally ) centered on the woofers dustcap from 1 Meter away.
I'll PM you with my email address so that you can send me the .mdat file .
cheers <> Earl
EDIT: PM sent with email address
Also ( after looking at the combined responses > it looks like your tweeter is still flipped to negative polarity ) .
All drivers need to be working in the same ( + ) polarity.
See this image ( of the necessary test setup > this is what the combined-component curve looks like if the woofer offset is 2.5" ) ;
New crossover for my current speakers-curve-fitting-acoustic-offset-2-5in-calcs-png
File Type: png Curve-Fitting for Acoustic OffSet 2.5in calcs. C.png (42.4 KB, 122 views)
New crossover for my current speakersHide this!Advertise here!
Do i need analog active Crossover or Digital Crossover for DIY home theatre speakers? dipankar862 Multi-Way 43 16th March 2017 05:55 AM
Crossover for current drive mashaffer Multi-Way 21 20th February 2017 08:38 PM
crossover for current-driven Magnepan MMG Sandor Planars & Exotics 1 18th January 2016 02:27 AM
Current drive for speakers 454Casull Multi-Way 11 7th April 2009 04:16 PM
current speakers mcmahon48 Multi-Way 0 12th December 2008 02:38 AM
