New crossover for my current speakers
Old 13th July 2018, 09:16 PM   #91
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
I have been thinking about maybe going active but it feels like a lot of work. The opendrc-di does not work for active speaker setups. For that I would have to go to a much more expensive dsp option or go with an analog minidsp and that's not something I want to do (I want to do as few analog/digital conversions as possible. I have a really competent two channel amp now that I got as a real bargain a couple of months ago (S.A.T Amplifix, basically the same as Primare/Bladelius). Having a passive crossover would make things a lot easier and less complicated. Money isn't really an issue, I have a well paid job and live pretty frugal but I just want to be sure that I spend my money well.
My audio and DIY blog: http://phimusic.blogspot.se/
Old 15th July 2018, 01:19 PM   #92
EarlK is offline EarlK  Canada
Niklas,
I looked at your recent shopping list and disagree with some of the choices.
ie; IMO, money can be saved in some areas and then better spent in others.
I'll publish my choices later today.
Old 15th July 2018, 03:38 PM   #93
Here's how I would spend your money on crossover parts.
Some of the parts are much better ( IMHO ) while others ( like the BiPolar electrolytics ) aren't .
The Bipolars are mostly cascaded ( bypassed ) with MKP types ( & where it matters a Mundorf Supreme in the HF circuit ).
On balance, I feel this will give you better performance.
PS: you'll need to do your homework on whether or not this is a good company to deal with.
Old 15th July 2018, 10:56 PM   #94
Hi Niklas,
I've made a couple of changes ( nothing major that impact the above parts list ).
I tweaked the design to make C2 smaller ( note: C2 is now in the HiPass circuit ).
The notch filter ( comprising R3 + C5 ) is no longer needed ( but might be in the future if you ever fix your 5K diffraction suckout ) .
New crossover for my current speakers-morel-mtm-16-51mm-png
I've also included the XSim file for this version ( in case you or anyone else wants to play with it ).
PS: I could tighten up the phase tracking > but then I'd have to consider not using your existing LC components.
File Type: zip Morel CAT408+CAW638_LineSourceEFK_H7_3x3.zip (836.5 KB, 0 views)
Old 16th July 2018, 12:14 PM   #95
Rullknufs's Avatar
Thank you, Earl! So I should skip buying parts for R3+C5? Also, how does reducing C2 from 25 to 14.7uF affect the sound/XO point? And why the drastic reduction (only 60% of the previous value).
Old 16th July 2018, 12:40 PM   #96
Pano is offline Pano  United States
Pano's Avatar
Please help keep your forum clean. Do not quote the entire post just above yours. (see the Rules). Over quoting has been removed. Thank you.
Old 16th July 2018, 02:45 PM   #97
Buy the 4 parts needed for ( R3 + C5 ) x2 . They are only 5.56 euro total. You might need them later.
C2 can be changed back to the 24.7uF value by paralleling a 10uF biPolar cap ( already in the shopping list ) to the existing 14.7uF film caps ( which is a 2 cap combo consisting of a 10uF MKP film + 4.7uF Supreme film paralleled together ).
- Then you can tell me if you hear a difference! ( for a 15uF or 25uF cap in that position ).
Old 16th July 2018, 03:16 PM   #98
Rullknufs's Avatar
Alright, thank you! What is the 8.2ohm resistor meant for? I can't see it in the schematic.
Old 16th July 2018, 04:19 PM   #99
That's one possible value for R3 ( ie; not used at this time ).
Old 20th July 2018, 10:42 AM   #100
Rullknufs's Avatar
Okay So, is there anything else that I would need? I have solder, soldering iron, and cables. I will make a thin wooden board to mount the components on. Is glue best for mounting the components? If I remember correctly my current crossover has the components glued to a plywood board. It wont be pretty getting them off the board.
New crossover for my current speakersHide this!Advertise here!
Do i need analog active Crossover or Digital Crossover for DIY home theatre speakers? dipankar862 Multi-Way 43 16th March 2017 05:55 AM
Crossover for current drive mashaffer Multi-Way 21 20th February 2017 08:38 PM
crossover for current-driven Magnepan MMG Sandor Planars & Exotics 1 18th January 2016 02:27 AM
Current drive for speakers 454Casull Multi-Way 11 7th April 2009 04:16 PM
current speakers mcmahon48 Multi-Way 0 12th December 2008 02:38 AM
