Max SPL of a loaded box?
Old 14th November 2017, 01:51 PM   #1
cpc748 is offline cpc748  United States
Default Max SPL of a loaded box?
I have a question regarding max spl output of a speaker box. Let say I have a 2 way box frequency response from 37hz to 21Khz max output of 137dB.
Does that mean I'm able to get 137dB out of it given the correct amplifier at full range of play back 20hz to 20Khz or is the box rated at a certain frequency not full spectrum?
Old 14th November 2017, 04:16 PM   #2
weltersys is online now weltersys  United States
weltersys's Avatar
Most manufacturers rate "Max SPL" as a peak at some frequency presumably within the pass band of the speaker within the rated power, with no power compression, that is, "cold" voice coils. The peak could be much shorter than one that would be read on a typical SPL meter.
Reducing 10 dB (or more) from the rating often gives a more "real world" rating.
Old 23rd November 2017, 12:09 AM   #3
Thank you, I kind of figured that I just needed to confirm
Old 23rd November 2017, 07:33 AM   #4
chris661 is offline chris661  United Kingdom
chris661's Avatar
What Art said.
Here's an article I wrote out of frustration at the industry's current state:
Spec Wars: Looking Inside Loudspeaker SPL Specifications - ProSoundWeb
Chris
Max SPL of a loaded box?Hide this!Advertise here!
L Loaded ZV9 Help??? flg Pass Labs 76 23rd December 2016 10:28 AM
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 08:32 PM
Back loaded, front loaded, Iím confused! Silent Screamer Subwoofers 23 4th May 2013 08:54 PM
Combination of Back-loaded Horn and Fron loaded horn?! ARIYAHOOR Full Range 26 1st June 2012 09:20 PM
Loaded Question dr._sleep Tubes / Valves 2 23rd November 2005 09:23 PM
