Small waveguide/horn for Eminence ASD1001
Old 13th November 2017, 02:50 PM   #1
sese317j is offline sese317j  Germany
Default Small waveguide/horn for Eminence ASD1001
at the moment im building a small pa system with the Monacor sp8/150Pro and the Eminence asd1001 compression driver. Now i'm searching for a small waveguide with a horizontal dispersion of 60 - 90. The heigth of waveguide is limited to 5'' due to the small cabinet. The crossover freq. is 2.5-2.7khz
Sebastian
Old 13th November 2017, 04:00 PM   #2
Charles Darwin is offline Charles Darwin  United Kingdom
P-Audio PH-2510 100x80 horn, 112mm high.
Or their PH-2513 but that is 132mm high.
Cost around 8-10 each here.
Choice is rather limited for screw-ons.
Old 13th November 2017, 09:11 PM   #3
i think i found a canidate, the Goldwood GT-400PB
Old 13th November 2017, 10:35 PM   #4
badman is offline badman  United States
badman's Avatar
That goldwood is going to have poor sonic quality (Vague imaging, harsh, particularly on loud passages, basically the bad aspects people react to as "horn sound", which isn't present in modern devices) due to the diffraction features. I'd suggest trying to find a smooth-wall horn if you can.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 13th November 2017, 11:31 PM   #5
djk is offline djk
R.I.P
djk's Avatar
That Goldwood GT-400 horn sounds quite poor, the GM-500 sounds vastly better (you can trim the mounting flanges).
The PRV Audio WG23-25 is also better (you can trim the mounting flanges).
Candidates for the Darwin Award should not read this author.
Old 13th November 2017, 11:38 PM   #6
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
XT120
Or huge Celestion H1-8050 - Thomann UK
flesh flash flush
Old 13th November 2017, 11:54 PM   #7
djk is offline djk
R.I.P
djk's Avatar
Nice horns (I have the XT1464), but I don't think he will be able to trim the flange down enough.
Faital Pro STH100 - Faital Pro STH100 1" short elliptical tractrix horn. Faital Pro STH100 elliptical tractrix horns available here at US Speaker.
I have a pair of these too, they might be what he needs (with an adaptor). They should work well crossed at 2.5Khz to his 8".
Old 14th November 2017, 12:10 AM   #8
Flaesh's Avatar
SICA horns are cheap and smooth, but driver mounting is abnormal. Horn 119x119 mm, for 1 inch Sica compression driver
I have Q07015A modified with standard flange added)))
May be JBL made some small horns for screw drivers?.
flesh flash flush
Old 14th November 2017, 06:06 PM   #9
Thank you, this is just what i was looking for. It perfectly fits my desired dimensions. And its even easy to get in germany
Small waveguide/horn for Eminence ASD1001Hide this!Advertise here!
Hifi Suitable Horn Waveguide for 2" Compression driver - Eminence H2 EA, P-Audio Pippi Lindenstroem Multi-Way 18 20th September 2017 04:54 PM
Small fullrange for waveguide loading Defo Full Range 6 25th May 2010 08:14 AM
small horn + waveguide PA? max axe PA Systems 49 8th March 2010 06:54 AM
