Audibility of speaker nonlinear distortion - test
Old 14th November 2017, 03:52 PM   #41
PMA is offline PMA  Europe
PMA's Avatar
Thanks to all who posted the results on sine tones.
I have prepared a test with real music. Distortion has been added mathematically, which is always a pain, because in the real speaker the distortion depends on frequency and higher amplitude may excite further distortion, non-harmonic. Both I am unable to simulate.
The distortion profile used is attached and applies only for amplitudes as in the plot. For smaller amplitudes, distortion is decreased, which is similar to normal speaker.
Test files are at
http://pmacura.cz/flute.zip
It is a flute concert and forte is in the second half of the sample.
Please try the files and in case of a positive abx result, please post it here. I can make everyone sure that this test will be much more difficult than those with the sines.
Old 14th November 2017, 05:43 PM   #42
Mooly's Avatar
I would like to say I got a positive result (I did) but I couldn't repeat the trick The following tests I ran gave a 6/8 and then a 5/8. Maybe fatigue was setting in.
Code:
foo_abx 2.0.4 report
foobar2000 v1.3.16
2017-11-14 18:23:00
File A: flute distorted.wav
SHA1: 2fb3327e56efb5a10ec5783b4cc3848b56a29be8
File B: flute.wav
SHA1: acef85edba0a2bc1b5ae970763d8f5ea389bd98a
Output:
DS : Primary Sound Driver
Crossfading: NO
18:23:00 : Test started.
18:23:25 : 00/01
18:23:58 : 01/02
18:24:11 : 02/03
18:24:35 : 03/04
18:24:45 : 04/05
18:24:55 : 05/06
18:25:07 : 06/07
18:25:18 : 07/08
18:25:18 : Test finished.
Total: 7/8
Probability that you were guessing: 3.5%
 -- signature --
40234b358700d19b12d8ff2107952ba7264471c1
Code:
foobar2000 v1.3.16
2017-11-14 18:31:11
File B: flute.wav
Output:
Crossfading: NO
18:31:11 : Test started.
18:31:58 : 01/01
18:32:15 : 02/02
18:32:27 : 02/03
18:32:39 : 03/04
18:32:54 : 04/05
18:33:07 : 05/06
18:33:17 : 05/07
18:33:35 : 06/08
18:33:35 : Test finished.
Total: 6/8
Probability that you were guessing: 14.5%
 -- signature --
068f88e392ef9b1f4024f2be23591b2b4899a37d
Old 14th November 2017, 05:47 PM   #43
PMA's Avatar
Wow, that is a great result, Karl!!!
Have you concentrated on the drum bang, or an a flute?
Old 14th November 2017, 05:57 PM   #44
Mooly's Avatar
It was on the flute. I can't even honestly say in what way it sounded different, maybe timbre on the harsher leading edges.
Old 14th November 2017, 06:17 PM   #45
PMA's Avatar
See how the distortion is fading away (esp. high order components) as the signal is decreased ....
Old 14th November 2017, 06:25 PM   #46
Pano is offline Pano  United States
Pano's Avatar
The Rouse flute concerto is much harder than the pure tones - and flute is a rather pure instrument. I think I can hear some differences, but so far not ABX success.
Here is another version of the same piece.
YouTube
Take the Speaker Voltage Test!
Old 14th November 2017, 07:01 PM   #47
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by RNMarsh View Post
Well, this should settle the matter. Scott and Geddes and any others who dont seem to believe one can hear much of anything in the way of distortion.
Sine waves are not music and speakers do not have constant distortion with level or frequency. I do see JBL does not see fit to make that information readily available. Carry on with this if it makes you happy.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 14th November 2017, 07:48 PM   #48
PMA's Avatar
We do not test on constant distortion with level.
Old 14th November 2017, 09:48 PM   #49
You'll have to convince me there exist (serious) speakers that are expansive and compressive. Not to say there aren't any but how about monotonically decreasing non-linearities before the exotic stuff.
Old 14th November 2017, 11:51 PM   #50
Well, this should settle the matter. Scott and Geddes and any others who dont seem to believe one can hear much of anything in the way of distortion. I would guess they have not spent much time critically listening.
Dick you should go to Burning Amp sometime, I'm sure you would be a big hit.
Audibility of speaker nonlinear distortion - testHide this!Advertise here!
Audibility of nonlinear distortion - new listening test PMA Everything Else 23 5th December 2015 01:43 PM
YADAT: Yet Another Distortion Audibility Test fas42 Everything Else 3 21st May 2013 04:41 AM
MP3 Compression Artifact Audibility Test SlunkBoy Digital Source 9 23rd March 2011 11:40 PM
Audibility of nonlinear distortion Pan Multi-Way 37 4th December 2008 07:41 PM
Audibility of Distortion Listening Test...FUN! MJL21193 Everything Else 57 20th February 2008 09:13 PM
