Peerless SLS
Peerless SLS
Old 2nd April 2004, 06:54 AM   #1
Mats J is offline Mats J  United States
Default Peerless SLS
Anyone know who in the States carries the SLS line from Peerless?
TIA-
Mats J
Old 2nd April 2004, 09:54 AM   #2
5th element is offline 5th element  United Kingdom
5th element's Avatar
SLS Platform
A new class of midbass and subbass drivers from Peerless.
SLS platform: Only available for OEM-customers.
Direct from peerless site.
This doesnt mean its gonna be impossible to find them if a supplier buys a set as OEM customer and sells them like you get retail and OEM computer parts. But I think your chances are slim.
Whats your plan for these? If its just a cheaper alternative to the XLS, then Id just save up and get the XLS rather then spend lots of time and energy trying to find a supplier. I do know that one thing to do would be to ask a supplier what it would cost to supply them. I once did this at wilmslow audio here in the UK, they didnt have a driver I was interested in so I emailed them asking for a quote. It was inline with what you would expect, no price hike because they didnt stock it either. This was a peerless driver also, a HDS one, but the HDS series are available anyway unlike the SLS series.
Good luck Matt
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 2nd April 2004, 12:14 PM   #3
Thanks, I missed that OEM only part.
Old 2nd April 2004, 12:36 PM   #4
PHilgeman is offline PHilgeman  United States
PHilgeman's Avatar
Send a message via AIM to PHilgeman
I believe Madisound stocks the 8", or at least they have a few. Give them an e-mail
Old 2nd April 2004, 01:27 PM   #5
frez is offline frez
Here in Sweden there is no problem to get hold of theese drivers. I cannot se why this would be a problem in the states. Where in www.d-s-t.com does it say it's strictly OEM? I can't find it.
/Frez
"I never forget a face, but in your case I'm ready to make an exception."
Old 2nd April 2004, 01:50 PM   #6
Its under the engineering section of DST.
Old 2nd April 2004, 02:39 PM   #7
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Peerless SLS
Mats:
They seem to be similar to the CSX series only with higher Qts. Were you planning these for open baffle use? Otherwise, the CSX or HDS would seem to be a better choice.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 3rd April 2004, 07:11 AM   #8
Yeah, the idea was for an inexpensive 10" OB. Oh well, the search goes...
Old 3rd April 2004, 08:13 PM   #9
rho is offline rho  Belgium
The SLS series is available for everyone. Atleast since this year they are.
Old 4th April 2004, 12:10 AM   #10
angel is offline angel  Norway
In Norway, at least, both the SLS and SDS drivers are available from www.dynabel.no at reasonable prices.
And they do have rather high Qts values. How about putting them on a U shaped dipole baffle?
* SLS315 woofer (12") to 315Hz. USD 100ea.
* SDS134 mid (5") to 4kHz. USD 37ea.
* CT62H tweeter (1.5" cone) to 20kHz. USD 21ea.
Should be reasonably priced, with a pleasant performance, even using simple crossovers. In fact, with a notch filter on the mid, it wouldn't need a lowpass, and for the rest, except the tweeter, you could go for first order filters with zobels. Put a second order and zobel on the tweeter.
Peerless SLSHide this!Advertise here!
peerless xxls sealed -vs- peerless xls with passive radiator Naudio Subwoofers 8 23rd March 2008 10:00 PM
Peerless SLS 400 4real Multi-Way 12 26th October 2005 06:37 PM
WTB:Peerless bhg41088 Swap Meet 1 6th July 2004 11:41 PM
Whats the difference between the Peerless 831916 and Peerless 850122 SkinnyBoy Multi-Way 9 12th June 2003 04:11 PM
Peerless Vivek Parts 10 23rd June 2001 12:25 PM
