2-way Unity Horn from 300Hz (some noob questions)
Old 12th April 2018, 07:45 PM   #61
nc535 is offline nc535
Congratulations on your academic progress/survival!
Yes to your question re' ATC. Answer can be found in HR help file
You should know that the rest of the world does exit angle matching before round to rectangular After all, what is the point of not matching the exit angle of the CD until you've completed the round to rect? Can you maintain the CD's angle through that conversion process? I can't visualize that.
Here is an example of a throat for a 60x60 horn I've been and am still working on, in Sketchup no less. Where the CD attaches, a tangent to the front to back curve of the throat matches the internal cone of the CD. At the other end of the throat, at the mid points of the sides, the tangent is at 30 degrees, the half angle of the horn flares. From the mid points to the corners, I've drawn 3 point arcs with two points being on the throat and the 3rd pointing being in the corner itself. This is a big improvement over what I showed back in November. The primitive straightline corner fill I had then would have been a diffraction source.
The idea is to 3D print this piece and finish the rest of the 60x60 horn with plywood. This drawing has some 1/64th inch scale defects in it but they can be repaired at the makeprintable website, for example. This would cost about $100 to print so I'm looking at printers...
File Type: jpg throat_four_quads_exploded and joined.jpg (404.0 KB, 271 views)
My Synergy Corner Horns and Bass Bins
http://www.diyaudio.com/forums/multi...bass-bins.html
Old 14th April 2018, 10:02 AM   #62
MrOIL is offline MrOIL  Germany
Hi Jack,
As I am not in a hurry, I think I should start all over from the beginning and implement everything that I learned from this project so far. I would start with the adapter, finalize it and then do the plywood horn. Your idea of implementing the ports in the adapter is interesting, but think I'll still put them on the plywood so I could try different positions/sizes, if I'm not satisfied with the results.
So my goal here is to make an (almost) perfect throat adapter and do some experimenting with the plywood in front (also allowing for 3way loading, if I need that in the future).
I still want to use the DE250 driver but it's exit angle isn't really clear to me. Some people say it's 14.6, some 12, some 13. Which one should I use?
Also how long should the exit angle matching and the elliptic to rectangular conversion be?
Thanks a lot!
Old 14th April 2018, 01:47 PM   #63
Hi MrOil:
If you haven't already, you should check out this thread for another example of how to do an adapter and lots of good ideas.
3D printed 3-way Unity waveguide home audio speaker
As to my own adapter, I made a convenient choice as to where to end the adapter and begin the plywood and the holes fell where they fell. I don't think its any harder to drill or fill holes in plastic then plywood. Heck, you could even 3dprint plugs. Its more accurate to have the ports done by computer control than manually guided and life is easier if you do enough and complete enough simulation not to have to move them.
The more difficult question is re' how much distance on axis the exit angle matching and round to rectangular conversion should take up. In general, you want to complete the transition (just) before you get to the edge of the mid port holes. Beyond that is a judgement call. As you work through it you will get a feel for it. I started with the idea of using 1/3 of the distance for exit angle matching and that seemed to work.
I'm doing a square horn, Bwaslo like you is doing a rectangular horn, which is why I referenced his thread. The square horn is easier but that is what I need for my application.
Old 15th April 2018, 12:53 AM   #64
Soldermizer is offline Soldermizer  United States
Soldermizer's Avatar
Some of us (like me!) took the easy way out:
Yorkville
Which is an honest-to-Patent-Office Unity horn from 300 Hz up. I got mine used at about 1/4 of new price, so semi-DIY
Performing unnatural acts to circuits since age ten
Old 16th April 2018, 02:14 PM   #65
I have no idea how to do the round to elliptical conversion in SketchUp or any other program I know of and neither do I know how to describe the shape I'm looking for to Google... Do you now one way?
Thanks a lot!
Old 16th April 2018, 03:43 PM   #66
How well do you know Sketchup?
If you don't know it well, then you have a Sketchup learning curve to traverse as well.
Regardless, there are a number of extensions, mostly free, you will need:
to cleanup loose ends and fix microscopic gaps
Cleanup
SolidInspector2
to draw ellipse and superellipse
Curvemaker
Arcs, Circles +
to make surfaces spanning the arcs, ellipses you've drawn
Bezier Surfaces from Curves
Those are tools that you would need. I can't give you a process because I've never done it myself. Perhaps someone who has will speak up.
I think you start by doing the exit angle matching round throat. Then draw a succession of ellipses each centered on and a little bit further down the throat from the end of that round section. The trick is knowing how to size those ellipses. They need to be connected by arcs that extend the arc of the throat out to the corners of the horn. Perhaps you start by drawing one such arc, perhaps the straightest one which should more or less bisect a corner and then make the endpoints of your ellipses land on this arc. My thought is you need the ellipses to define the arcs however I should point out that I was able to do my round to square without a succession of circles. The arcs just fell where I needed them using the 3 point arc tool with two points in the throat and the third point in a corner.
The above may not work but it should get you started and to the point where you can find a solution.
Once you have arcs and/or ellipses you can use the Bezier surface tool to complete it. Then cleanup and then solidinspector.
Old 16th April 2018, 03:50 PM   #67
I have figured it out without any extensions...
How do I make this grid a surface?
Old 16th April 2018, 04:05 PM   #68
The Bezier Surface from Curves extension will do it. It costs $4 but you can get a free trial
Select a pair of adjacent arcs from among those running front to back. Then select the tool in the Draw menu, then select "ruled triangles"
A surface between the pair of arcs is created
Old 21st April 2018, 01:02 PM   #69
I tried the primitive round to rectangular transition first. I think difraction would occur on the red marked part...
What do you mean by "two ponts at the throat" (regarding the three point arcs).
What is the Problem with rond to square before exit angle matching?
It is so much easier to do...
Also: What is the cheapest/easiest way to make rearchambers for the mids?
Thanks a lot!
Old 21st April 2018, 02:08 PM   #70
Yes, I agree that diffraction would occur off the edges you've marked in red.
I see that in your throat, going front <> back behind that marked edge you have straight lines, ostensibly matching the exit angle of the CD. Those straight lines should be curved arcs that just come tangent to the exit cone of the CD where the CD attaches.
The other ends of four of those arcs should come tangent to the horn wall where they touch the horn walls. This occurs in 4 places - on the midpoints of the horn walls.
What do we do about the front to back arcs in between those points of contact? Extend them continuously into the closest corners.
If you are using Sketchup and you zoom in you will see that Sketchup draws each arc as a series of straight line segments. Pick a segment endpoint of an arc several segments deep into the throat as the first point of your 3 point arc. Pick the endpoint closest to the throat as the second and pick the corner as the third point to use the 3 point arc tool to extend the throat into the corner. Experiment on first point choice and location of corner. If the corner is too far into the horn this method might not work.
How do you define and draw those arcs? In the last picture I showed some number of posts ago I defined it graphically/geometrically by the tangency requirements. I then took a look at the OS spreadsheet that I think you can download from BWaslo's thread and found my graphically defined curve was within a few hundredths of an inch of the spreadsheet curve, as far as it went.
Once you've drawn the curve, convert it to a surface by drawing a line between its ends and then use the follow me tool to trace it around the 1" circular CD entrance hole to create the 3D surface.
But how far should it go; how deep into the horn should this curved throat extend before converting to square or rectangular? I've been doing some Axidriver sims to shed some light on that. My sims show that .3cm is at least marginally better than .4cm or .2cm. Too short and the HF suffers. Too long and the on axis null gets worse. The on axis null should only be an artifact of the axisymmetric simulation. It should not be a problem with a rectangular horn. It may be a problem with square horn but less of a problem than with a round horn. So take my .3 cm recommendation with a grain of salt; it might all come from the axi symmetry.
(Does anyone know how much on axis null to expect in square horn vs round?)
As to your question about why not round to rectangular first, I gave the reasons I had in an earlier post. Perhaps if you draw me a picture I'll understand better what you mean have some insight.
2-way Unity Horn from 300Hz (some noob questions)Hide this!Advertise here!
60-300hz other than horn loading noviygera Subwoofers 8 16th June 2017 06:25 AM
50-300Hz front horn arcgotic Multi-Way 29 22nd January 2016 01:26 PM
Questions on Synergy/Unity Horn rb132333 Multi-Way 26 9th October 2015 08:49 PM
Horn for <300hz? rvrazvan Multi-Way 5 19th August 2011 03:44 PM
searching for a 40hz-300hz bass horn patriz Multi-Way 8 1st November 2003 09:16 AM
