My bluetooth speaker project
Old 4th November 2017, 07:34 PM   #11
ZipSnipe is offline ZipSnipe  United States
Yes it shuts down upon turning on the amp. Like I said it runs fine off the wall wart. The specs on the amp call for no less than 12volts 3.5 amps input voltage. The specs on the battery are 12v 3 amps. The battery seemed quite light from the get go, I was suspicious it would power it at all.
Old 4th November 2017, 08:23 PM   #12
Mooly's Avatar
Threads have been merged. One thread per topic please. Both this and your other thread were discussing batteries and power sources.
Old 4th November 2017, 10:53 PM   #13
Originally Posted by infinia View Post
Investigate Hobby Lipo battery packs.
look here Lipo Finder
Thanx Infinia, I know all about hobby batteries, I fly several types of drones weekly. I am looking towards a compact all in one li-on designed battery that has the charger and protection circuit built in
Old 5th November 2017, 03:58 PM   #14
cfaye is offline cfaye
Sounds like the protection board is kicking in. I bet that is also probably a 3s batter. So 12v when newly charged, but really only a 10.8v battery in use. You will probably have more luck with your 4s Makita pack. Even better would be a 5s for 18v tools. They provide a lot of amps and it is easy to find legitimate 5ah packs.
Old 5th November 2017, 10:03 PM   #15
Well I am looking at these sla batteries, had I thought about the battery situation a lil more before I put my front woofer plate on(wood glued), the batteries would not be that big of a deal . The only batteries that will fit are too underpowered. And the batteries I need are a just too big. The drill batteries will only run it for about 15 to 30 minutes ,maybe an hour at half volume. So maybe I will pry the front plate off so I can get a bigger battery up inside the woofer enclosure.
Or....maybe just leave it as a wall wart speaker :-(
Old 6th November 2017, 07:30 AM   #16
infinia is offline infinia  United States
infinia's Avatar
7AH SLA is only rated for long term current draw @ low current ~C/20. Pulling 3A from will give you about 1/4 of its AH & drawing it down any longer than that decreases avail battery cycles E.g lifetime. so this path leads to bigger, heavier, and less run time than a 18V 2AH tool battery. If you really want to run off of batteries use low volume Spl's, or higher efficiency amp and speakers. Do a search for 'Boominator' for solutions..
Rather than dismissing my suggestions, tell us why this wont work. AFAIK this is the most compact battery w/ good cheap chargers, all avail. off-the-shelf.
Old 7th November 2017, 03:20 AM   #17
The problem with lipo's would be the maH rating, most only go up to 5500maH and I really need 15 to 40 aH . Unless I am wrong and lipo's maH rating is different than other batteries? I mean I guess I can try out a lipo I do have a 4s 4200maH lipo from my large drone I could try
Old 7th November 2017, 10:32 PM   #18
Ok test was great, ran the speaker at 90% volume for 30 minutes and only dropped .4 volts on my 4s 4500maH 14.8 volt lipo which means I could safely run it 2 1/2 hours at 90% volume if needed.
This is great because, now I can buy batteries for this and still use them on my drone of needed !!!
Old 8th November 2017, 12:26 AM   #19
That's good news! You should get yourself a BMS, or at least a voltage alarm. Lipos are expensive to brick.
Old 8th November 2017, 05:10 AM   #20
infinia's Avatar
Do some more current draw measurements. Play with the volume and find a sweet spot for low power dissipation. Your reported 3A is plainly stupidly high for any reasonable battery packs. You would be lucky to get 45 minutes w/o going in to early cell death territory. I doubt you can estimate run time from looking at voltage drop. Only if you have the data and done several discharge curves from actual empirical tests. I have a feeling the Lipo packs are aggressively optimistic their ratings compared to top tier 18650 cells.
OR just find the weakest cell under load and monitor it with a cheap DMM done...
My bluetooth speaker projectHide this!Advertise here!
Project BIG 'Bluetooth' Spkr Djryderz Multi-Way 34 31st March 2017 03:35 PM
Bluetooth speaker project - need help with amp input voltage (TPA3110, MAX9736A) 13ms13 Class D 7 29th March 2017 08:25 PM
My Diy speaker bluetooth project, help me :) maxita Construction Tips 3 4th February 2016 08:35 AM
70's Cable radio Speaker to Bluetooth Speaker vvvyper Full Range 14 22nd May 2013 05:45 PM
Ultra Portable Bluetooth Boombox Project - need some help pigboi808 Chip Amps 0 28th August 2011 05:08 AM
