Can you hear the crossover point of a speaker with a well-designed crossover?
Old 2nd April 2004, 02:50 AM   #11
catapult is offline catapult
Default The question is the answer....
The definition of a "well-designed" crossover is one where you can't hear the transition. So, by definition, the answer to your question is no.
Old 2nd April 2004, 05:48 AM   #12
Shaun is offline Shaun  South Africa
Shaun's Avatar
Default The crossover is only half the story...
Firstly, the drivers need to be of similar technology, so that the radiation pattern can be similar. For instance, it's not easy to integrate a monopole configured driver with a dipole configured driver, because of the different power fall-off rate as the distance from the source is increased. But it's not impossible to achieve good result this way.
Then, the correct crossover point and driver sizes should be chosen, or you'll get a poor off-axis response (1" dome tweeter with 10" woofer is good example of a bad combination), as the radiation pattern of a dynamic driver narrows with increased signal frequency. A driver typically has good dispersion at the lower frequencies, but starts to beem at the upper end. So you need to cross over to the next driver before the off-axis response of the driver in question falls off too much. And the next driver has to have sufficient power handling capacity, or it will result in distortion. (When I say "next", I'm progressing from lower frequency to higher).
Good off-axis response is essential in a reverberant/"live" environment. Now, it is acceptible for the system response to roll off when observed from off-axis, but the transition must be smooth, with minimal dips or peaks.
Look up some nice papers from Harman Kardon on this subject. I don't have the urls, sorry.
Hope this helps...
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Can you hear the crossover point of a speaker with a well-designed crossover?Hide this!Advertise here!
Can you HEAR OUT different crossover slopes? RussianBlue Multi-Way 7 21st March 2014 07:45 AM
Designed my first crossover, tell me what you think, graphs inside pjpoes Multi-Way 7 8th March 2007 11:09 AM
Newbie - Designed crossover - Pls let me know if its okay Ronnie22 Multi-Way 12 11th August 2005 08:30 PM
I finally designed and built my first crossover! Jim85IROC Multi-Way 17 26th May 2004 07:27 PM
Point to point crossover soldering Ilianh Multi-Way 9 24th December 2002 04:14 AM
Copyright ©1999-2017 diyAudio
