Outboard crossovers for 3 way speaker - closer to amp or speaker?
Old 12th October 2017, 09:09 PM   #1
Grannyring is offline Grannyring
Default Outboard crossovers for 3 way speaker - closer to amp or speaker?
Ok, I have an upgraded outboard crossover. Should I place it close to the amp or speakers when dealing with cables as long as 15-18 feet? Which way makes the most sense in terms of sound quality? Thanks all.
98db effeciency. 6 ohm. Three way. 80 watt SS amp.
Old 13th October 2017, 12:30 AM   #2
DiscoJones is offline DiscoJones  United States
As long as you're using the same gauge wire before and after the crossover, then closer to the amp is better, but only because you're using triple thickness wire for most of the run. Even then you're talking about hundreths of ohms (assuming you're using at least 14ga wire to begin with). My advice would be to use the thickest gauge you want to spring for and put the crossover as close to the speaker as possible, just to minimize the wire mess.
Dan
Old 13th October 2017, 02:39 AM   #3
Fernando R is offline Fernando R  United States
You will certainly use less wire close to the speaker. Those who favor bi or tri-wiring, the running of individual wires to each driver, may come up with a justification for the longer run being individual to the driver. Maybe a bi-wiring thread could stir up some opinions. I for one agree with DiscoJones. Use a heavy enough gauge and minimize the mess. If you are married, you may get a very strong vote for close to the speaker with minimum spaghetti.
He uses numbers and statistics like a drunk uses a lamp post; for support rather than illumination.
Outboard crossovers for 3 way speaker - closer to amp or speaker?Hide this!Advertise here!
when to recap speaker crossovers? Doggyboy Multi-Way 3 16th December 2014 02:29 AM
Speaker crossovers Vaughan Multi-Way 12 12th April 2013 01:06 PM
is current in speaker load to be anyway closer to psu current ratings? rhythmsandy Solid State 50 10th December 2012 09:50 AM
FS: Magnepan MG12 outboard crossovers (upgraded) jhoak Swap Meet 0 13th July 2012 04:34 PM
Speaker crossovers lduarte1973 Multi-Way 7 18th May 2011 11:51 PM
