F.A.S.T speaker design questions?
Old 11th October 2017, 05:08 PM   #1
Cintronic is offline Cintronic  United Kingdom
Default F.A.S.T speaker design questions?
I am curious to try a F.A.S.T set up and before even thinking of speaker types and details I need to understand some basics first.
I am concerned about matching output speeds from different types of designed. I prefer the sound of sealed subs, can the full range be a horn/ TQWT or would it not be a good match?
Is it advisable that the FR speaker design needs to cut off at same frequency as the crossover cut off point e.g. Port tuning/ TQWT length or does this not matter?
Any other advice to get a coherent design to work would be welcome.
Old 11th October 2017, 05:24 PM   #2
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
There is no such thing as "speed" in speakers. There is poor integration of bass and mid frequencies.
If you like a sealed sub, fine. Use a sealed full-range. Pick a sub that can cross at 300Hz give or take. Ideally no higher to preserve the linear phase characteristics of the full-range. Pick a full-range as small as you can that will cross at 300Hz.
Of course reality dictates moving the cross-over to match the choice of drivers. My personal speakers use the Audax HM210C0 and the Scan Speak 10F-8424G0 crossed at 500Hz with a Harsh phase linear XO.
Bob
Old 11th October 2017, 05:24 PM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Usually a WAW (Woofer assisted wideband… there is finely a move to lose the FAST moniker) has an XO high enuff that one does not need to attempt to extend the LF and sealed or aperiodic midTLs (or OB) are commonly used.
Like any XO the cutoffs need to create a smooth hand-over. That is specific to the exact implementation.
I am rushing away at the moment, i can post a lot more on the subject including examples we have built.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th October 2017, 05:36 PM   #4
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
We may have to put the TLA to a vote
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 11th October 2017, 06:44 PM   #5
Jerms is offline Jerms  United Kingdom
Have a look at the Nautiloss topic if you want interesting "sealed" and damped TL.
Or The Dagger. Both by XRK971
Sealed plus a Linkwitz transform seems a good idea for bass. Should result in a smaller package but excursion is king.
J.
Old 11th October 2017, 06:48 PM   #6
Small sealed box EQ'd for bass is only worth considering if small is the priority
Old 11th October 2017, 06:54 PM   #7
chrisb is offline chrisb
As usual, Uncle Bob's advice is right on the nose.
OK, Scott, I'll bite "TLA" = Transmission Line, Aperiodic ? I see Dave is still catching up to your new testament acronym
Jerms - doesn't the LT suck up a lot of power? Mind you, thanks to classD, that's probably never been cheaper per watt.
like my mind, this space intentionally blank
Old 11th October 2017, 06:57 PM   #8
Three Letter Abbreviation
Old 11th October 2017, 07:47 PM   #9
clever boy
Old 11th October 2017, 10:22 PM   #10
Vs a ported or TL, much more power would be required to extend low response. It all has to come from the front wave.
How the driver response scales vs power becomes an issue possibly. Assuming two woofers rather than a single sub....
F.A.S.T speaker design questions?Hide this!Advertise here!
Multiway SEAS Speaker design questions bassmann4020 Multi-Way 26 19th May 2018 04:59 AM
Speaker Design Questions BasicHIFI1 Multi-Way 23 9th March 2016 05:05 PM
Speaker design questions: dimensions sfhseric06 Multi-Way 11 17th January 2008 10:17 AM
Nooby speaker design questions weinstro Multi-Way 5 27th September 2007 11:11 PM
Speaker design, X-Over, and MTM Questions - Please help a noob! sbolin Multi-Way 39 4th October 2004 05:14 PM
