Kef Reference Model Three Schematic
Old 13th October 2017, 03:17 AM   #11
gavmak is offline gavmak  United States
Oh Lojzek now I see what you are talking about with the pic of the traces. I will get a better pic just need a day or so to take it apart. And get you a better shot. Cheers
Old 16th October 2017, 06:10 PM   #12
Originally Posted by Lojzek View Post
This is blocking my view of the traces. Thanks so far.
Here are some more shots.
Old 16th October 2017, 06:48 PM   #13
andy2 is offline andy2  United States
Sin Bin
Originally Posted by gavmak View Post
Now days kef uses expensive poly caps but not back when these were made, I will be using a mix of poly caps and in some areas there will probably be Mundorf supremes. Can I prove and do I believe their is a difference that is quantifiable in dollars to performance improvement? Probably not. I do know that it makes me happy to know the parts I use are more than adequate. I used mundorfs step below the supremes in a pair of Q75 to rebuild the xovers and was very happy so picked up a pair of reference Kefs of the same era and figured I would see how far I could take them with the same approach.That being said is it the best value proposition probably not.
I was being sarcastic.
Old 16th October 2017, 06:56 PM   #14
oh oops tuff to tell with typing vs talking. cheers
Old 16th October 2017, 08:37 PM   #15
Sin Bin
I actually believe expensive caps do make a difference. But most of the time, I am so good at optimize my xover that they don't make that much difference or not much that it matters. Also my hearing at high freq. is pretty crappy they I probably can't hear the difference anyway. The only question is if the power specs of the low end cap are good enough to handle the power.
Low end caps like those surplus sold by Madisound like who knows since you don't know their specs and they look sort of out of place on my optimized xovers. I am weird in a sense that part of the reason I like high end caps because of their looks. I believe it's more important for high end audio to look good first then sound good in that order. Products from Sonus Faber and Dynaudio is probably 80% looks + 20% sound. I once listened to a pair of Sonus Faber which to me sounds pretty good, but then I went home and listen to mine and they are not all that different (not to mention my cheap home audio gears are an order of magnitude less expensive than those paired with Sonus Faber at the demo room). But I have to admit Sonus Faber speakers are the most sensual, seductive, and killer looking than any out there. They just have that perfect proportion. I ran my hands over those speakers and I swear my girl friend was no comparison.
Old 17th October 2017, 03:18 PM   #16
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
This should be it.
A good dialogue makes you feel like a changed person, not like you have won or lost the competition.
Old 23rd October 2017, 12:57 PM   #17
Thanks so much now I can get started.
Old 23rd October 2017, 06:18 PM   #18
Lojzek's Avatar
You're welcome. Will you be updating the schematic here so we know the rest of the missing inductor values, resistor and one cap?
Old 23rd October 2017, 07:10 PM   #19
oh of coarse it looks to be a 5mfd cap and the mills resistor i placed in there as a replacement with a lower value to help tame a large curve in the impedance measurements. It only helped a little. The measurements weir taken with Dats 2 software and strange;ly are far from flat but match left to right pretty close.I will upload what I have as far as those measurements go if I can find the files.
Old 23rd October 2017, 07:44 PM   #20
Here are some of the measurements I took a while back. I will update with the inductor values when I get a chance to pull apart and measure.
File Type: pdf Kef Red three left with resistor change =7ohm.pdf (265.7 KB, 11 views)
File Type: pdf Kef Red three right with resistor change =7ohm.pdf (259.7 KB, 5 views)
Kef Reference Model Three SchematicHide this!Advertise here!
LME49610 Reference Schematic hopkinskong Chip Amps 21 27th May 2017 01:18 PM
FS: KEF Reference Model Two, Great Condition, MA/NH Local baco99 Swap Meet 2 10th November 2016 04:48 PM
Which UCD*HG for my KEF Reference Model 2 Groucho2004 Class D 0 26th January 2014 12:22 AM
Kef Reference Model 4's Burnedfingers Multi-Way 1 20th December 2002 01:35 AM
Pioneer Model C-90 Reference Control Amplifier Cobra2 Solid State 6 4th November 2002 01:17 AM
