Dampening a must? - Page 3 - diyAudio
Old 1st April 2004, 06:00 PM   #21
moving_electron's Avatar
Location: Where the rain does fall but the trees grow tall
Originally posted by Seth Smith
Here is an interesting link that may prove helpful on the subject of stuffing to manipulate Q:
Polyester Fiberfill Effects on Box Q
Very helpful link.
Thank you
Old 2nd April 2004, 12:32 PM   #22
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Used to is the key phrase here........
Perhaps it was the Man in the White Suit?
Old 2nd April 2004, 01:07 PM   #23
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
IME the usual white polyester damping material deadens the sound quite easily, so you shouldn't use too much.
I replaced the white stuff in my previous (DIY) speakers with soft, foamy noduled carpet underlay. The improvement in sound quality was huge. Whether you achieve the same benefits will depend on using the correct stuff, and presumably your loading type and driver(s) and x-over used, and other factors.
My current speakers are soon to receive the same treatment, as my brother has just had new carpets fitted and had loads of nice underlay spare
Currently, I am using several layers, only on the inside surface of the cabinet, of the more rubbery and flat underlay - this does not have the same effect.
If you do decide to try underlay, don't coat all surfaces, as this will probably take too much life away, just like using too much white foam.
Anyone else tried underlay?
dampening a cd player Joe04 Solid State 0 29th February 2004 10:42 PM
help on dampening please welly_59 Multi-Way 5 25th November 2003 03:35 PM
DIY Dampening Radik Multi-Way 17 18th November 2003 05:53 PM
dampening Stryder Digital Source 39 7th January 2003 02:42 AM
Dampening in a car dsanders Multi-Way 4 29th October 2001 04:31 AM
Copyright 1999-2017 diyAudio
