Old 31st March 2004, 10:31 AM   #1
Default Vifa, extra lines in response curve graph?
This is the MG10SD09-04 from Vifa
Could anyone tell me what the extra lines are for?
Different ohmage? I need an answer so I can make a good descision on purchasing..
If anyone would like to tell me the best Vifa bass/mid/tweeter drivers out there for a 3-way I'd be much appreciated
Old 31st March 2004, 10:38 AM   #2
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default Lines
Hello,
My guess is (From the top down):
Blue: On axis response
Green: 30 degrees off axis
Red: 60 degrees off axis
Blue: impedanse magnitude free air
Hope it helps
\Jens
Old 31st March 2004, 10:39 AM   #3
Frank Berry's Avatar
This is a short description of the measuring methods used at vifa/scan-speak.
FREQUENCY RESPONSE
The frequency response curves are measured in one of vifa/scan-speaks anechoic chambers.
The chambers are 6x7x8 meters which gives a lower cut-off frequency at 100 Hz.
The curves are measured in 0°, 30° and 60° with microphones in a distance of 1 meter. The input voltage is 2.83 V.
One of the walls in the anechoic chamber is without damping material and acts like an infinite baffle (2-pi room) for the driver. Behind the driver is a closed box - typically at 320 litres.
Frank
Old 31st March 2004, 10:48 AM   #4
Thank you!
Is there a 'king' crossover design which works well with a midrange efficient cabinet???
I /can/ buy the components for crossovers and make it myself, however buying outright /is/ easier and if I was to buy components myself I will still need a design to follow :\
I've heared vented designs are mostly for High Fidelity.
Is there any tried and true method with Vifa drivers and vented 3-Way designs????
Which is the better response curve here.... Foxx510 Multi-Way 6 21st March 2007 10:46 AM
Why does the BiB's frequency response graph go all spazzy, and why can't we hear it? Spasticteapot Full Range 6 7th November 2006 09:56 AM
When reading a response graph... mazeroth Multi-Way 4 27th August 2004 09:38 PM
frequency response graph acceptable? tech.knockout Multi-Way 15 28th June 2003 05:23 AM
response graph for scan speak ttvonau Multi-Way 12 4th June 2002 08:53 AM
Page generated in 0.08084 seconds (73.17% PHP - 26.83% MySQL) with 11 queries
