Restoration
Restoration
Old 10th November 2017, 09:29 AM   #51
muzyk_ant is offline muzyk_ant  Romania
Send a message via Yahoo to muzyk_ant
Does anybody know how to "restorate" and soften an older rubber woofer sorrounding? Saw something with alcohol and wintergreen oil. Anyone tried that, or some other mothod?
I want to make those sorroundings a little softer but on the other side don't want to ruin them with some chemicals.
Old 10th November 2017, 12:20 PM   #52
Kay Pirinha is online now Kay Pirinha  Germany
Kay Pirinha's Avatar
First of all: Why do you want to modify your speakers?
2nd: Are you really sure that the surroundings once were softer than today?
3rd: If so and in general, be aware that softeners evaporate during time and cannot be put back.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 12th November 2017, 05:14 AM   #53
Best regards!
1-Kay, want them to lower Fs as much as it is possible.
2-Well, not sure aobut that, it may be possible that they where the same but I've seen softer on newer woofers so that's why I put in mind to try to make them a little more flexible.
3-you are right about that, I've read that people tried to soften the inside spider with acetone and other stuff and indeed it gets softened but after a while all gets as the prior state.
One thing I will try to "break" the woofers with a 20-40 Hz sweep for a while see what it happens. The thing is that theese woofers where kept for some years unplayed on the shelf and I definitely hope to get more response from them.
All the best !
Old 12th November 2017, 10:48 AM   #54
My lb3521's also don't present that deep bass, most probably due to their moderate volume.
Best regards!
RestorationHide this!Advertise here!
AR11 restoration Libertyphile Subwoofers 13 8th January 2016 05:39 PM
AR3a restoration. SatinMill Multi-Way 46 25th December 2014 12:47 PM
1300DC Restoration mechanicalman Solid State 2 4th February 2009 04:25 AM
Photos of my restoration binary Solid State 23 17th November 2006 11:58 AM
Old violin restoration Panicos K Instruments and Amps 2 2nd November 2006 02:06 PM
