Restoration
Restoration
Old 12th October 2017, 12:54 PM   #31
muzyk_ant is offline muzyk_ant  Romania
Send a message via Yahoo to muzyk_ant
I guess this will have to do : Click the image to open in full size.
Got them at 44 eur including shipping. They are original Heco-s that have the same dimmensions with TC-245.
The rubber suspension is perfect, but one of the woofers has it's dust cap folded in. Can you guys reccomend a way to get that dust cap back as it was or do I have to change those two dust caps witha new pair ?
Old 12th October 2017, 03:34 PM   #32
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Try to sting a thin pin into the cap's center, tilt it sideward and pull this damned thing out with it.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 13th October 2017, 08:01 AM   #33
They are 3.4 Ohm DC so I guess pretty close to the originals in that respect. Thank you Kay!
The woofers come from a pair of Heco Precision 300 speakers Heco Precision 300 | Audio Dynosaurs | Pinterest. The precision 300 also have the cuttof freq for the woofer at 700 Hz and 25Hz response...pretty sweet, so I guess theese are the perfect compromise.
I guess I will change the dust caps on both with some black new ones.
Can anyone reccomend me how to get that outer sealing ring because the woofer needs to be mounted from inside the box.
Cheers
Old 13th October 2017, 09:35 AM   #34
Boden is offline Boden  Netherlands
Hello muzyk_ant.
As Kay Piranha stated, these woofers are way over-priced. 10 Euro a pair is already too much.
Living in Amsterdam, more than once have I found much better loudspeakers literally on the sidewalk, waiting for the garbagemen to pick them up the next morning.
As for the rings: you can either use 6 mm MDF and saw them with a jig saw, or use thick card board. Card board can be cut with a Stanley Knife.
Good luck,
Eelc
Old 13th October 2017, 10:05 AM   #35
Hi Eelco, well the thing is that I found them close to me and they arrived in one day. I know they are overpriced and for this price I would be glad to find some new woofers replacement but unfortunately "they don't make them as once did" .
Tell you a secret... those loudspeakers that you see on the sidewalk for free are collected by Romanian "friends", they bring that back and sell those for 100-500 eur a pair God I hate those good fellas
WIll try to cut a cork gasket from a thick sheet if not a card board of some sort... Thank you for the ideas !
Old 13th October 2017, 10:13 AM   #36
Hi Boden,
I had referred to the over-priced epay offer of defective woofers in post #28. I'd also pay 44 EUR for a pair of suitable and working drivers, though, if I'd wish to get the existing, but not complete speaker pair working again. We sometimes do things that can't be explained rationally :-).
@muzyk_ant: As you won't see the woofers through the front grille and as the damaged cap still will just work as a dust cap without any sonic impact in the region below 700 Hz, you also may leave it as is. First replace the cardboard rings, 2nd install the woofers, 3rd listen and enjoy :-).
Best regards!
Old 13th October 2017, 10:20 AM   #37
AllenB is offline AllenB  Australia
I agree that this probably won't be a problem. If you find yourself in on a rainy day, hold the dustcap at the edge with your fingers and pull it out with a vacuum cleaner.
Old 13th October 2017, 11:49 AM   #38
Quote by Muzyk_ant:Tell you a secret... those loudspeakers that you see on the sidewalk for free are collected by Romanian "friends", they bring that back and sell those for 100-500 eur a pair God I hate those good fellas
Funny thing is, these fellas have proven to be unable to recognize AR 3A's, AR 4's, some KEF's and a pair of Celestion Dittons 66.....
Old 13th October 2017, 12:23 PM   #39
You must be a very lucky fellow, Boden !
Btw, perhaps I should have added that I like those WEGA speakers very much, especially by their design. As said some posts above, I own pair of lb3520's (version unknown, 3-way, 8" woofer), lb3521B's (3-way, 10" woofer), and lb3522C's (4-way, 12" woofer). The latter ones are in daily use at the moment. The 3520's and 3522's share the design with the OP's pair (aluminium-like front grille, anthrazite coloured body), the 3521's are plain white. The 3520's are both as tall and as wide as the 3521's, but only half as deep. WEGA suggested them to be mount to a wall and provided appropriate holes at the back. No surprise, they lack some bass response.
Best regards!
Old 13th October 2017, 03:36 PM   #40
Allen, no more rainy days till next year for me so maybe a snowy don;t go to work day :P
Eelco, these fellas don;t distinguish a mini fridge from a speaker so don't ask too much
Kef , Dittons thrown away... well.... lucky you
Kay, 3520 sealed speaker but not so sealed ? well my next diy project will definitely have in mind some 12" compression/sealed woofers
These Wega speakers are very interesting as design ... as the corners are all rounded up, maybe they did know about the cabinet difraction after all? The thing is I wanted to ask you guys about this protection grill. Will this drilled grill influence sound as some sort of sound diffuser Planet Of Tunes - Acoustics at some freqencies or it doesn;t matter at all being so close to the sound source?
Kay I know the protection grilles are glued to the speakers but I wish to make them mine removable ones. What about a comparisson bewthen this tipe of grill and the tipical cloth grill?
RestorationHide this!Advertise here!
AR11 restoration Libertyphile Subwoofers 13 8th January 2016 05:39 PM
AR3a restoration. SatinMill Multi-Way 46 25th December 2014 12:47 PM
1300DC Restoration mechanicalman Solid State 2 4th February 2009 04:25 AM
Photos of my restoration binary Solid State 23 17th November 2006 11:58 AM
Old violin restoration Panicos K Instruments and Amps 2 2nd November 2006 02:06 PM
