Old 31st March 2004, 04:17 AM   #1
azira is offline azira  United States
Default How to measure BL (is it important for TL?)
I've got some off brand 8" drivers that I replaced in some 3-ways I had. But the other speakers are crap now and I've been following the TL threads. So I decided to measure up these drivers and throw them into MKs worksheets.
I used speaker workshop to measure them but it doesn't measure BL. I put the numbers into the worksheet anyway and changed BL around to see if it would do anything. It seems to have some pretty noticable effect.
So, how do I measure BL.. or is it actually important for a TL?
Old 31st March 2004, 05:49 AM   #2
BoxModel, freeware by Bullock and White, calculates the BL, among other things, from the other Thiele-Small parameters.
You can download it yourself if you want, or you can give me the following parameters and I will do it for you:
Fs
Vas
Qes
Qms
Re
Sd
PS: If you download it yourself, ignore the TL program. They admitted themselves that it does not predict TL behavior well. The other programs included are very good and accurate, however.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 31st March 2004, 06:15 AM   #3
frugal-phile(tm)
planet10's Avatar
BL = f(Fs, Vas, Qes, Qms, Re, Sd)
Anyone got a formula for the above handy?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st March 2004, 06:37 AM   #4
Don't have the formula. I just plug the numbers into BoxModel and out comes the answer.
I'm sure there is a formula out there somewhere.
-Anonymous
Old 31st March 2004, 09:28 AM   #5
Svante is offline Svante  Sweden
Svante's Avatar
Well, since
Qes=1/(ws*Cms*Res) and
Cms=Vas/(rho0*c^2 *Sd^2) and
Res=(Bl)^2 / Re
Bl=sqrt((rho0*c^2*Sd^2*Re)/(ws*Vas*Qes))
rho0 = density of air =1.2 kg/m^3
c = velocity of sound = 345 m/s
Sd = Equivalent piston area in m^3
Re = voice coil DC resistance in ohm
ws = 2 *pi * fs
fs = free air resonant frequency of the driver in Hz
Vas = Volume equivalent to the cone suspension
Qes = "electrical" Q value of the driver
and sqrt... meaning the square root of ...
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 31st March 2004, 09:39 AM   #6
frugal-phile(tm)
planet10's Avatar
thanx...
saves me digging it up.
dave
Old 31st March 2004, 03:28 PM   #7
Originally posted by Svante
Well, since
Res=(Bl)^2 / Re
ws = 2 *pi * fs
Thanks Svante..
Interesting, all those parameters are either constants in the mathcad worksheet or values one enters for T/S parameters. I wonder why it doesn't calculate Bl for you...
Here's the parameters I measured:
Fs = 53.5 Hz
Vas = .931 cu-ft
Qts = .692
Qms = 3.291
Qes = .875
Le = .612 mH
Re = 7.6 Ohms
For Sd: speaker is 8" so the cone diameter is really 7" right? So this is 3.5" radius -> 8.89 cm -> .0889 m.
So Sd = .0889^2 * pi = .0248 m^2 right?
Danny
Old 31st March 2004, 03:39 PM   #8
Svante's Avatar
Fs = 53.5 Hz
Vas = .931 cu-ft
Qts = .692
Qms = 3.291
Qes = .875
Le = .612 mH
Re = 7.6 Ohms
Danny
I just randomly selected a 8" Peerless driver, it had a Sd of 235 cm^2 or 0.0235 m^2 so that seems OK. 0.931 cu-ft would be 26.4 litres or 0.0264 m^3. You could measure the diameter with a ruler of course to get the correct area.
So, your Bl should be 9.3 if I type the numbers right on my calculator.
Old 31st March 2004, 04:40 PM   #9
Hmm... the units don't seem to line up on the equation, what am I missing?
Bl = N/A or V*S/m or Tesla-meter
Old 31st March 2004, 05:27 PM   #10
Using 214 sq cm as the Sd, (which should give negligible difference from 235 sq cm), BoxModel gives me 7.93 Tm as the answer.
I have found BoxModel to be reasonably close to the published specs in the past.
Is there a mistake here?
By the way, sensitivity comes out as 88.6 dB per watt-which with that high voice coil resistance will be somewhat different from 2.8 volts.
-Anonymous
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 09:18 PM
Important!!! Clarkcr The Lounge 4 15th September 2004 03:34 AM
where is short wiring in an amp important/ not important ? sandro600 Solid State 5 4th April 2004 03:10 AM
Bl important? pkgum Multi-Way 2 1st January 2002 04:07 PM
Page generated in 0.11489 seconds (79.18% PHP - 20.82% MySQL) with 11 queries
