Old 31st March 2004, 03:10 AM   #1
Question Using Wavetools to measure T/S parameters
I've got some cheap 2nd-hand full-range drivers that I'd like to measure a few T/S parameters for (I've never done this before). I've down-loaded Paul Kellet's Wavetools program to use as a signal generator. What level of signal output should I use when I measure the driver's impedance vs. frequency curve? Would the signal output of my laptop be sufficient or should I run it through my 50-watt amp at full volume?
Thanks,
Joseph.
Old 2nd April 2004, 11:03 PM   #2
Anyone?????
Old 2nd April 2004, 11:15 PM   #3
markp is offline markp  United States
Try about 1 watt, 2.83volts into 8ohms.
If it sounds good... it is good!
Old 2nd April 2004, 11:21 PM   #4
claudio is offline claudio  Italy
claudio's Avatar
Thiel and Small parameters are refered to small signals, that is, from my point of view, more or less 1 volt. The output of your laptop should be sufficient, but you have to be sure that it is capable to output a clean signal; for sure your ampli should be better, since it is supposed to be Hi-Fi.
Claudio
Old 3rd April 2004, 05:16 AM   #5
Thanks for your help.
Old 3rd April 2004, 05:36 AM   #6
frugal-phile(tm)
planet10's Avatar
0.5-1.0 V out of the amp
http://www.diysubwoofers.org/measure.htm
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Somone in Oz to measure TS parameters? k-k-k-kenny Multi-Way 9 1st June 2009 02:41 AM
What do i need to measure speakers. Juggy Multi-Way 5 17th June 2008 04:48 PM
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 09:18 PM
How can I measure T/S parameters? MUPASTHECH Subwoofers 5 25th July 2005 02:32 PM
Can you measure Sd? ultrachrome Multi-Way 12 28th March 2003 04:37 PM
Page generated in 0.08053 seconds (69.96% PHP - 30.04% MySQL) with 10 queries
