Hello,
I have a question regarding the optimum number of drivers one can include in an enclosure. I have designed an enclosure for my Woofer using the T/S parameters( Software - WinISD). The enclosure volume comes to around 2 ft^3 for optimum Gain response curve. It is tuned at 40 Hz. By the way, the intention here is to build a decent sounding Floor Stander/Bookshelf. Now when I look at the SPL plot, it shows a max SPL of around 75db. Then I go ahead and increase the number of drivers to 2 in the same enclosre dimension. I see tha that the SPL plot has jumped to around 80 dB. Hence my doubt here is whether there are other things to keep in mind while using two woofers of the same kind in the same enclosure. Is it enough that I manipulate the tuning frequency to get a flat Gain response and maintain the higher SPL dB. Will this work out for the better? All responses welcome. Thanks in advance, Linoj. |
#2 |
Speakerholic
Hi Linoj,
If you have designed your box for one woofer, that's what to put in it. To achieve your goals with two woofers, you double the size of the box. Cal |
#3 |
75db is awfully low. What driver is it?
#4 |
hi
most probably you are facing a phase shift problem do you have access to an RTA ? place a seperation baffle in between the enclosure housing each driver mount each driver at the centre of its individual enclosure that is the rear air (behind the driver) should load the driver evenly then place both ports at exactly the same positions , distance from the driver and the enclosure sides , in their individual enclosures this should fix the problem some what from here on a RTA is required to improve further yet you will improve to about 85 db s at the max as 75 db s are too low to start with and i guess you are using Boltons suranjan transducer design engineer |
| Two identical drivers | HogieWan | Multi-Way | 3 | 12th December 2005 08:10 PM |
| implications of splitting cables | smak | Multi-Way | 1 | 20th October 2005 08:18 PM |
| Is this driver identical to the FE-103? | bigwill | Full Range | 7 | 1st May 2005 05:33 PM |
| What would be the effect if 2 identical drivers are ...? | Lito | Multi-Way | 1 | 13th October 2003 09:42 AM |
| Page generated in 0.07250 seconds (80.04% PHP - 19.96% MySQL) with 10 queries |
