Compression driver attenuation help..
Old 14th September 2017, 06:18 PM   #11
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Allen,
Nothing wrong with using a Zobel on a CD if it makes your HP filter behave better.
Best,
E
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 15th September 2017, 08:58 AM   #12
AllenB is offline AllenB  Australia
Erik, I may have assumed too much .
In regards to you referring to 'a Zobel', where Zobel compensation as I see it is a state, and a Zobel network is not a predetermined network, I thought I'd clarify because this is often unclear to newcomers and compensating a compression driver is so much harder than most common drivers, as you know.
Old 15th September 2017, 09:07 AM   #13
marco_gea is offline marco_gea  Italy
On the one hand, this is true.
On the other hand, though, IF you pad down the driver by at least 10dB or so with a suitable L-pad or with an autoformer + shunt resistor, then the resulting impedance will be almost perfectly flat.
Marco
Compression driver attenuation help..Hide this!Advertise here!
My next compression driver chris661 Multi-Way 24 22nd August 2016 06:34 PM
Compression driver help please chris661 PA Systems 34 16th February 2015 01:17 PM
Driver Attenuation ?? pa1x pro elite Parts 0 16th July 2012 09:20 AM
Driver Attenuation Circuit what watt resistor to use? noahtheviking Multi-Way 2 13th April 2011 06:33 AM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 01:09 AM
Copyright ©1999-2017 diyAudio
