Does anybody know of any other materials that can be used to fill a large void in a speaker. For instance if you wanted to fill in the area behind an internal curved corner (with the outside of the box being square) what material would you use. Is there any thing besides concrete? I would just go with concrete but i have to stack these things 8 high and im concerned about busting through the floor of my house... If bondo is effective, is there a cheap place to get this other than lowes/home depot which charges ~$25 for a paint can sized container?
#2 |
I'd try that expandable insulation foam that comes in a can. If you need large amounts I think you can also buy the two part mix, but they probably don't carry that at home depot.
#3 | |
2) Do you need the material to have similar strength as the enclosure itself? 3) What type of wood is the speaker made with?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 |
question 1: here's a pic the dimentions are about 31'' x 31'' x 20'' high for the whole structure, and im filling in the voids behind the rear curved corners.
question 2: the structural strength will all be taken care of by the box its inside of question 3: its mdf, but im planning on just having a few dowels going through it to hold whatever in place. |
#5 |
Use dry sand. Works like acharm to dampen out vibrations. And it's cheap.
Mark
Mark |
#6 |
I'd use white stryrofoam blocks from a craft store, glued up with 3M 77 to thickness, and cut on a bandsaw to radius. Lightly sand to even, and finish w/ water-based Rustoleum. Maybe 1 hour of work here.
speaker |
| filling a sub enclosure | Dan2 | Car Audio | 8 | 9th May 2009 07:44 AM |
| Filling enclosures | avatar307 | Multi-Way | 5 | 22nd December 2003 05:50 PM |
| Page generated in 0.10560 seconds (69.83% PHP - 30.17% MySQL) with 10 queries |
